I’m trying to automate the flow ‘Google Sheets → Webflow CMS’
This is the error I’m getting in the webflow node, can anyone help me here?
Error: ‘Issues: There was a problem loading the parameter options from server: “Bad request - please check your parameters”’
I double checked the site ID and collection ID are correct, also checked the Oauth integration in webflow…All access rights are given in this integration.
Hi @Ajmal_Shaik
Welcome to the community
Could you share your workflow with us? When you’re in the workflow editor view, you can hit ctrl/cmd + a and then ctrl/cmd + c to copy all your nodes and their settings. If you place this between two sets of three backticks (```) or hitting the </> symbol in the editor, you can then share your workflow with us with any sensitive credentials omitted
It would be helpful as well to some sample data of what you’re trying to send from Google Sheets over to Webflow, as well as know the following:
- n8n version:
- Database (default: SQLite):
- Operating system:
