When I select settings in any workflow I have created I get this message
Problem loading settings
The following error occurred loading the data:
Request failed with status code 404
How do I fix this error
Note: Execution Order: is v1(recommended)
Grot
2
Edit: Misread @King_Samuel_David solution seems like the first to try. Are you running n8n on cloud ore are you selfhosting.
So you can’t access setting as you get the error, have you tried a restart? it may just need to reload everything.
Best regards,
Samuel
I did the restart as suggested and that fixed the issue
Thank you
system
Closed
5
