Problem of JSON parameters in HTTP request when trying to post to linkedin
Hey chat so i’m having issues executing a http request to linkedin because of the JSON error
It keeps sayong JSON parameter needs to be valid JSON. ive checked the reples on here and nothing has worked so far
(Select the nodes on your canvas and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow.){
  "nodes": [
      "parameters": {
        "method": "POST",
        "url": "https://api.linkedin.com/v2/ugcPosts",
        "authentication": "predefinedCredentialType",
        "nodeCredentialType": "linkedInOAuth2Api",
        "sendHeaders": true,
        "headerParameters": {
          "parameters": [
              "name": "Authorization",
              "value": "Bearer {AQW0a2Z0NS0FHEgvc7aqB5bHlsvn2j5IRqMRTk38rVJp7vEC3jPlHQA2A9w5ZyBpGl9quooIWqH7kLnAVVpoo3FhWBEQoeghsGMSEfp0nfTpnk1TbdpUfgl4mBzcj6ik1bvaYw9Ab-3Vl9vlH3DqAUbbngt4k-M8BC_lMdH0dTlcjopiVvWy63pNdI9rBKnFb3_FxphRu7RfO6JNMk_kCbmaKpivrrR9tnfCGw5hbfRc5Y5ydLaieeNcg24_XhV6oD5x-upVyqYg3ZzL0q5kER4iDe3KYRwCr09OAjHJdeQHo_nEMerP2qiX8LN79en4CJNGcOO5hwhGStH_nFoSnmNWAMXEfA}"
              "name": "X-Restli-Protocol-Version",
              "value": "2.0.0"
        "sendBody": true,
        "specifyBody": "json",
        "jsonBody": "=\n{\n\"author\": \"urn:li:person:hfMGWGx_ow\",\n\"lifecycleState\": \"PUBLISHED\",\n\"specificContent\": {\n\"com.linkedin.ugc.ShareContent\": {\n\"media\": [\n{\n\"media\": \"urn:li:digitalmediaAsset:C5603AQHMl0UPKaPusw\",\n\"status\": \"READY\",\n\"title\": {\n\"attributes\": [],\n\"text\": \"Sample Video Create https://drive.google.com/file/d/1MPjwpomkkOBeGx5xWPgAZfO3EYIFZFUy/view?usp=sharing\"\n}\n}\n],\n\"shareCommentary\": {\n\"attributes\": [],\n\"text\": \"{{ $json.Caption }}\"\n},\n\"shareMediaCategory\": \"VIDEO\"\n}\n},\n\"visibility\": {\n\"com.linkedin.ugc.MemberNetworkVisibility\": \"PUBLIC\"\n}\n} }}}",
        "options": {}
      "typeVersion": 4.2,
      "position": [
        64,
        176
      "id": "9a5afe71-6a90-49a5-8aab-fbc34b172c1b",
      "name": "HTTP Request1",
      "credentials": {
        "linkedInOAuth2Api": {
          "id": "Cwvr4xK4pCJjlAv4",
          "name": "LinkedIn account 2"
        "linkedInCommunityManagementOAuth2Api": {
          "id": "abvivQvfwdjQCAP1",
          "name": "LinkedIn Community Management account"
  "connections": {
    "HTTP Request1": {
      "main": [
  "pinData": {},
  "meta": {
    "instanceId": "35ae3fe36b48e014c41aaf1c49b2748f208955a93f8c3f63d04a12883462b1b1"
  • n8n version: 1.108.1
  • Operating system: windows 10
Hi @Chinwe_Nwokoro welcome to the :n8n: community!
Try using this:
"text":  {{ JSON.stringify( $json.Caption ) }}
Also note that you can use the built-in Linked node to create a post,
Let me know if you still have any issues..
It still gives that same error. This is what it looks like
For the LinkedIn node I tried that and I had issues with credentials. The standard OAuth path stopped me from stopping while the community API said not enough callbacks even after I had created an app and added the client ID and secret
Hi, replace this please:
with this:
"text":  {{ JSON.stringify( $json.Title) }}
or just:
"text":  "title test"
I have done both and it’s still the same error
Should I copy the whole code on here
can you try this sample workflow:
you need to link Linkedin OAuth2 API
For this specific get URN it said forbidden something about the credentials. But I have a LinkedIn urn that I was able to get from my own httt request
Okay, let’s first ensure that authentication is working correctly.
Could you share what your scopes configuration looks like at Developers | LinkedIn
Are you trying to post to your personal account or a company account?
im trying to post on personal
Nice! So no need for complexity, just follow these steps to set up the LinkedIn node:
Generate a Client Secret:
Go to n8n and add your LinkedIn OAuth2 API details:
Create your post:
Okay the LinkedIn node works now
Thank you so much Mohamed :folded_hands:
Glad it worked @Chinwe_Nwokoro :tada:
Would you mind please like❤️ and marking the reply as the solution :white_check_mark:? Thanks!
