Problem passing the course level 1
Hello there, I have a problem passing the theory exam on course level 1, I have attempted many times but every time I get 69%, There might be a problem, Would anyone please help?
Hello,
What are your questions about the exam?
there is a problem with the exam i cannot pass above 69% in the theory!
Good evening @Ali_Tala
I just passed level 2, so I can assure you that there is nothing wrong with the tests.
I leave my suggestion for you and others who want to.
Go back to the beginning of the course and in each NODE, change the settings, alter, press the NODE initialization to test the behavior, move the NODES around…
Play around, have fun
Get a coffee and come back.
Stretch and come back again.
Make mistakes and make mistakes again… Because through mistakes you will learn cool things and different ways of doing the same thing.
Don’t be too hard on yourself, but make sure you are having fun…
After that you will see that the certification will come and you will be proud and at the same time you will have a lot of fun while learning.
A big hug @Ali_Tala
@Ali_Tala
The quiz has questions that have multiple answers. You need to select all correct answers for the question. You can tell which questions have more than one answer as they will not automatically go to the next question. Make sure you are selecting all answers that are correct.
