Problem returning binary data, Converting XML to XLSX using custom libraries
I’am using custom libraries in a code node to convert a XML file to a XLSX using xml2js and xlsx libraries. The issue is when I want to return in the output of the node the binary data seems to have another format like the expected by n8n so I cant download the binary file on my computer.
Please share the workflow
this is the output returned
and this is the expected output ( this is I want, can download the file)
  • n8n version: 0.203.0
  • Database you’re using (default: SQLite): MongoDB
  • Running n8n with the execution process [own(default), main]:
  • Running n8n via [Docker, npm, n8n.cloud, desktop app]: docker
Hey @aartaza,
I would have expected the output to be something like the below, Maybe that is where it is going wrong, So the data item would contain the binary data itself.
item.binary = {
        output: {
                data: $xlsxBinary,
                mimeType: 'application/vnd.openxmlformats-officedocument.spreadsheetml.sheet' ,
                fileExtension: 'xlsx',
                fileName: 'output',
