Running this code I have an error, but the code runs in VSCode
const sftpClient = require(‘ssh2-sftp-client’);
const fs = require(‘fs’);
const sftp = new sftpClient();
sftp.connect({
host: ‘sftp-slc.cmsw.com ’,
port: ‘22’,
username: ‘H_36266751’,
password: ‘’,
privateKey: fs.readFileSync(‘/Users/cassio/bosco/H_36266751.pem’)
}).then(() => {
return sftp.cwd();
}) .then(() => {
return sftp.list(‘/retorno’);
}).then(async data => {
for( var i = 0, len = data.length; i < len; i++) {
console.log(data[i].name);
const remoteFile = ‘/retorno/’ + data[i].name
const localFile = ‘/Users/cassio/bosco/’+ data[i].name
try { await sftp.fastGet(remoteFile, localFile) }
catch(err) {
console.log('GET ERROR = '+ err)
}).then(() => {
sftp.end();
}).catch(err => {
console.log(Error: ${err.message});
ERROR: Code doesn’t return items properly
Please return an array of objects, one for each item you would like to output
Error: Code doesn't return items properly
at JavaScriptSandbox.validateRunCodeAllItems (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/nodes/Code/Sandbox.ts:88:10)
at JavaScriptSandbox.runCodeAllItems (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/nodes/Code/JavaScriptSandbox.ts:70:15)
at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/nodes/Code/Code.node.ts:135:13)
at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/src/Workflow.ts:1307:8)
at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/src/WorkflowExecute.ts:1045:29
n8n version:
Database (default: SQLite):
Operating system:
n8n
November 29, 2023, 6:34pm
2
n8n version:
Operating system:
n8n version : 1.11.2
Database : none
n8n executions process : i don`t know
running n8n via npm
operating system : mac os
Hey,
You need to return the result as an array of objects.
Try something like this:
const sftpClient = require('ssh2-sftp-client');
const fs = require('fs');
sftp.connect({
host: 'sftp-slc.cmsw.com',
port: '22',
username: 'H_36266751',
password: '',
privateKey: fs.readFileSync('/Users/cassio/bosco/H_36266751.pem')
}).then(() => {
return sftp.cwd();
.then(() => {
return sftp.list('/retorno');
let results = [];
for (var i = 0, len = data.length; i < len; i++) {
const remoteFile = '/retorno/' + data[i].name;
const localFile = '/Users/cassio/bosco/' + data[i].name;
try {
await sftp.fastGet(remoteFile, localFile);
results.push({file: data[i].name, status: 'Success'});
} catch (err) {
console.log('GET ERROR = ' + err);
results.push({file: data[i].name, status: 'Failed', error: err.message});
return results;
.then(results => {
sftp.end();
// Return results to n8n
return results;
.catch(err => {
console.log('Error: ' + err.message);
Hi CristianG
Unfortunately, worked fine in VSCode, but not in n8n
I believe there is something different about how n8n runs JavaScript
Rgds
Jon
November 30, 2023, 4:21pm
6
Hey @cassiodamasceno ,
There is a bit of a difference because of the sandbox but we do also expect a specific return format which needs to be an array of objects.
Understood Jon
Could you help on how to change the code to acomplish this ?
Rgds
Jon
December 1, 2023, 5:16pm
8
Does the example provided by @CristianG not do it?
Jon
December 2, 2023, 8:53am
10
What is the node trying to return? It could just be that it wants a return at the end as well so maybe a return $input.all() at the end will sort it.
Jon, in fact, the only thing that this code does, is download files from a remote Sftp server and save them on a local directory
Jon
December 3, 2023, 11:43am
12
It still needs to return an array once complete as that is what we expect.
Understood
I believe the problem is that the code has many intermediate returns and not once complete
I’ll try to figure out how to resolve it
