Everything worked locally, but after deploying, my workflows started failing randomly. What changed
- n8n version:
- Database (default: SQLite):
- Operating system:
Hey @Heis_Femq Welcome to the n8n community !
Do youy mind sharing your workflow and the errors you are facing because there are many reasons this can happen as transition from test to production URLs (If you are using a webhook) , Having No Fallback Logic in AI Agents (Enable fallback model) , Not enabling error handling logic in node settings (have a separate branch to handle things when a node errors.),
You can also use a error trigger and configure to notify you about the errors if something happens in production,
Also if you’re self hosted then please recheck your base/Env variables.
WEBHOOK_URL, N8N_HOST, N8N_PROTOCOL, N8N_EDITOR_BASE_URL, VUE_APP_URL_BASE_API etc.
This is how users and webhooks actually reach n8n and sometimes if these variables dont match, you can see webhooks not firing, callbacks failing, or UI oddities.
I could assist you in more detail @Heis_Femq if i can have more context about the errors you are facing as well as the workflow, Appreciate it
Hi @Heis_Femq Welcome! Can you please provide more information about your workflow and the error.
Hello, there is likely nothing wrong with the logic in your workflow but rather a difference in the environment it is running in. This is usually caused by:
- Missing or different environment variables/credentials occurring in production.
- The local and production versions of n8n are different
- A switch to queue mode
- Webhooks pointing to test URLs and not production
- File system or resource limits
Start by analyzing your both your local and your production setup next to each other and check the error logs that are in production.
