Problem running worklfow
I’m running a self-hosted version of n8n in a Docker container, version 1.66.0
I have a simple workflow summarising some text and then using a “Convert to file” node. The input text is quite small but I always get the “Problem Running Workflow” (Execution data too large) error when testing the node. This is a problem as the input is generated by OpenAI so is costing me every time I run it. The workflow is successful when run as a whole.
Any settings that might help? I’ve tried the save execution data On and Off.
The workflow steps can be successfully run individually on the n8n cloud instance.
TIA
n8n version: 1.66.0
Datebase: PostgreSQL
n8n EXECUTIONS_PROCESS: set in docker-compose, initially set to own, this caused a startup error, setting to queue allowed the system to start but states that EXECUTIONS_PROCESS is depricated. This still produces a node runtime error.
Running n8n via: Docker - docker-compose
Operating system: Linux
The log file give the following output;
withpostgres-postgres-1 | 2024-11-12 16:22:50.095 UTC [27] LOG: checkpoint starting: time
withpostgres-postgres-1 | 2024-11-12 16:22:52.158 UTC [27] LOG: checkpoint complete: wrote 17 buffers (0.1%); 0 WAL file(s) added, 0 removed, 0 recycled; write=1.822 s, sync=0.052 s, total=2.063 s; sync files=16, longest=0.039 s, average=0.004 s; distance=45 kB, estimate=45 kB; lsn=0/296CB228, redo lsn=0/296CB1F0
withpostgres-n8n-1 | PayloadTooLargeError: request entity too large
withpostgres-n8n-1 | at readStream (/usr/local/lib/node_modules/n8n/node_modules/raw-body/index.js:156:17)
withpostgres-n8n-1 | at executor (/usr/local/lib/node_modules/n8n/node_modules/raw-body/index.js:113:5)
withpostgres-n8n-1 | at new Promise ()
withpostgres-n8n-1 | at getRawBody (/usr/local/lib/node_modules/n8n/node_modules/raw-body/index.js:112:10)
withpostgres-n8n-1 | at IncomingMessage.req.readRawBody (/usr/local/lib/node_modules/n8n/dist/middlewares/body-parser.js:40:56)
withpostgres-n8n-1 | at parseBody (/usr/local/lib/node_modules/n8n/dist/middlewares/body-parser.js:51:15)
withpostgres-n8n-1 | at bodyParser (/usr/local/lib/node_modules/n8n/dist/middlewares/body-parser.js:77:33)
withpostgres-n8n-1 | at newFn (/usr/local/lib/node_modules/n8n/node_modules/express-async-errors/index.js:16:20)
withpostgres-n8n-1 | at Layer.handle [as handle_request] (/usr/local/lib/node_modules/n8n/node_modules/express/lib/router/layer.js:95:5)
withpostgres-n8n-1 | at trim_prefix (/usr/local/lib/node_modules/n8n/node_modules/express/lib/router/index.js:328:13)
docker-compose;
version: ‘3.8’
volumes:
db_storage:
n8n_storage:
services:
postgres:
image: postgres:16
restart: always
environment:
- POSTGRES_USER
- POSTGRES_PASSWORD
- POSTGRES_DB
- POSTGRES_NON_ROOT_USER
- POSTGRES_NON_ROOT_PASSWORD
volumes:
- db_storage:/var/lib/postgresql/data
- ./init-data.sh:/docker-entrypoint-initdb.d/init-data.sh
healthcheck:
test: [‘CMD-SHELL’, ‘pg_isready -h localhost -U ${POSTGRES_USER} -d ${POSTGRES_DB}’]
interval: 5s
timeout: 5s
retries: 10
n8n:
image: docker.n8n.io/n8nio/n8n
restart: always
environment:
- EXECUTIONS_PROCESS=queue
- DB_TYPE=postgresdb
- DB_POSTGRESDB_HOST=postgres
- DB_POSTGRESDB_PORT=5432
- DB_POSTGRESDB_DATABASE=${POSTGRES_DB}
- DB_POSTGRESDB_USER=${POSTGRES_NON_ROOT_USER}
- DB_POSTGRESDB_PASSWORD=${POSTGRES_NON_ROOT_PASSWORD}
- N8N_BASIC_AUTH_ACTIVE=true
- N8N_DIAGNOSTICS_ENABLED=false
- N8N_USER_MANAGEMENT_DISABLED=true
- WEBHOOK_URL=https://xxx.xxx.xxx
ports:
- 5678:5678
links:
- postgres
volumes:
- n8n_storage:/home/node/.n8n
depends_on:
postgres:
condition: service_healthy
The input data is;
In his inaugural address on January 20, 1961, President John F. Kennedy delivered a powerful message emphasizing the celebration of freedom and the responsibilities of a new generation of Americans. He highlighted the challenges of the modern world, including poverty and tyranny, and called for unity in overcoming them. Kennedy pledged support for allies, efforts to assist the oppressed, and a commitment to peace through cooperation. He urged both Americans and global citizens to contribute actively to the common good, famously stating, “ask not what your country can do for you, ask what you can do for your country.” Kennedy concluded with a call for strength, sacrifice, and the pursuit of justice and freedom for all mankind, underscoring the importance of collective responsibility.
hello @Chiral_Systems
what are the instance parameters where you have the docker container?
Can you be more specific, I run the n8n container using the docker-compose file provided above.
what is the output of the command docker stats ?
CONTAINER ID   NAME                      CPU %     MEM USAGE / LIMIT     MEM %     NET I/O           BLOCK I/O        PIDS
3431f0c4af18   withpostgres-n8n-1        0.25%     111.1MiB / 15.33GiB   0.71%     45.2kB / 34.5kB   410kB / 75.7MB   13
6100e09cee14   withpostgres-postgres-1   0.06%     26.7MiB / 15.33GiB    0.17%     32.9kB / 36.1kB   2.13MB / 261kB   7
The memory is fine. Can you share the whole workflow?
Maybe the data for the whole workflow is big
It’s pretty simple; All nodes when run individually fail with the Data too large error. As a whole it runs just fine. Is this an n8n issue with the free version?
Can’t say why it happens. Maybe someone from n8n could help.
@Jon FYI
