i have some problem for setup user
the massage is
Problem setting up owner
Potentially malicious string
i don`t know why
my logs says
[license SDK] Skipping renewal on init: license cert is not initialized
Task runner connection attempt failed with status code 403
Version: 1.106.2
Editor is now accessible via:
Registered runner “JS Task Runner” (8RfdbTvpieWLptNW-gvd_)
(node:7) [DEP0060] DeprecationWarning: The util._extend API is deprecated. Please use Object.assign() instead.
(Use node --trace-deprecation ... to show where the warning was created)
but i have another node, in version 1.84.0, if i use same config from old version, and i login from emal and password. it working normaly
- **n8n version:1.106.2-arm64 **
- Database (default: SQLite):
- Running n8n via (Docker):
- Operating system:
