I am using version 1.32.1
After starting with Docker Compose below, when setting account information, I get this error:
Problem setting up owner
Request failed with status code 401
Please guide me if you know what the problem could be. ![]()
Docker-Compose:
version: '3.8'
services:
postgres:
restart: unless-stopped
image: postgres:16
container_name: postgres
hostname: postgres
networks:
- n8n-net
ports:
- "5432:5432"
volumes:
- /volume/n8n/postgresql:/var/lib/postgresql/data
environment:
- POSTGRES_DB=n8n_db
- POSTGRES_USER=n8n_app
- POSTGRES_PASSWORD=1111111111
n8n_app:
image: n8nio/n8n:1.32.1
container_name: n8n_app
hostname: n8n_app
networks:
- n8n-net
ports:
- "5678:5678"
volumes:
- /volume/n8n/data:/home/node/.n8n
environment:
- N8N_PROTOCOL=http
- N8N_HOST=0.0.0.0
- WEBHOOK_URL=http://0.0.0.0/
- NODE_ENV=production
- N8N_ENCRYPTION_KEY=XsfWKTgTS4uQiLlIP2qNYj11C
- N8N_LOG_LEVEL=error
- EXECUTIONS_DATA_SAVE_ON_ERROR=all
- EXECUTIONS_DATA_SAVE_ON_SUCCESS=none
- EXECUTIONS_DATA_SAVE_ON_PROGRESS=true
- EXECUTIONS_DATA_SAVE_MANUAL_EXECUTIONS=false
- EXECUTIONS_DATA_PRUNE=true
- EXECUTIONS_DATA_MAX_AGE=72
- EXECUTIONS_DATA_PRUNE_MAX_COUNT=50000
- DB_TYPE=postgresdb
- DB_POSTGRESDB_HOST=192.168.1.1
- DB_POSTGRESDB_PORT=5432
- DB_POSTGRESDB_DATABASE=n8n_db
- DB_POSTGRESDB_USER=n8n_app
- DB_POSTGRESDB_PASSWORD=1111111111
- EXECUTIONS_MODE=queue
- EXECUTIONS_QUEUE=redis
- QUEUE_HEALTH_CHECK_ACTIVE=true
- QUEUE_BULL_REDIS_HOST=192.168.1.1
- QUEUE_BULL_REDIS_PORT=6379
- QUEUE_BULL_REDIS_PASSWORD=1111111111
- N8N_DISABLE_PRODUCTION_MAIN_PROCESS=true
depends_on:
- postgres
n8n_worker:
container_name: n8n_worker
hostname: n8n_worker
networks:
- n8n-net
# ports:
# - "5678:5678"
volumes:
environment:
- N8N_PROTOCOL=http
- N8N_HOST=0.0.0.0
command: worker #--concurrency=10
depends_on:
- n8n_app
n8n_webhook:
container_name: n8n_webhook
hostname: n8n_webhook
networks:
- n8n-net
# ports:
# - "5678:5678"
volumes:
environment:
- N8N_PROTOCOL=http
- N8N_HOST=0.0.0.0
command: webhook
depends_on:
- n8n_app
networks:
n8n-net:
- n8n version: 1.32.1
- Database (default: SQLite): Postgresql
- Operating system: Ubuntu
