Problem using $ifEmpty expression with two values
I’m trying to write an expression to create a new JSON key:value inside an Edit Fields node.
I want to check if Value1 is empty, use it if it isn’t, and use Value2 if it is. Both existing values are strings.
The expression I have is:
{{ $ifEmpty( $json.Value1, “$json.Value2” ) }}
The problem is that when Value1 is empty, this returns as the literal string “$json.Value2”, not the contents of that respective value.
If I take the quotation marks away, I get a syntax error - it seems like they are a required part of the expression/function.
Is there a way around this? Or do I need to use this less elegant expression instead (which works, I just find it harder to read in more complex nested expressions)?:
{{ $if($json.Value1 == NULL, $json.Value2, $json.Value1) }}
Hi @REN87
What I usually do is (e.g. for string fields):
{{ $json.value1 == "" ? $json.value2 : $json.value1 }}
Assuming value1 is always defined and you’re just checking for empty string or not.
Hope this helps!
