Problem using Node.js modules within n8n function node
Running n8n via npm
Operating system: Windows
A basic problem :slightly_smiling_face: I am new to n8n, trying to run Node.js modules in a function node but It does not work for me.
Any help is appreciated.
Hi P.Y.
any further Information would help.
How did you set up n8n?
Did you follow along the documentation/ set the environment variables?
To use NodeJS modules, you need to set the following environment variables:
export NODE_FUNCTION_ALLOW_BUILTIN=*
export NODE_FUNCTION_ALLOW_EXTERNAL=*
The first is for allowing internal libraries, and the second is for external npm libraries.
Then import the library in your code node, using commonjs syntax.
Ex:
const cheerio = require(β€˜cheerio’);
Many thanks Akram. This was very helpful, it worked!
Glad it helped!
