Problem using WebFlow OAuth2
I’m trying to connect Webflow to n8n, but without success. The credential using OAuth2 doesn’t work, and the connection using the API token only works with Webflow’s legacy API, which doesn’t allow creating trigger nodes. I’ve noticed that the app used for OAuth2 in the cloud version, which is what I’m using, may not be requesting the necessary permissions for changes. Can you help me?
“Error fetching options from webflow trigger”
  • n8n version: Version 1.57.0 (cloud)
  • n8n version: 1.57.0
  • Database: default
  • n8n EXECUTIONS_PROCESS setting: default
  • Running n8n via: cloud
Hey @PauloAFA,
This error is becuse I forgot the Form scope when updating the node, This should be fixed in the release today.
Thank you for your response! I updated to the new version; however, the problem persists. The message “Error fetching options from Webflow Trigger” keeps appearing.
I’m using OAuth2 and I tested it with and without the legacy option selected. My n8n version is 1.58.1 (cloud).
I just saw that the Webflow update version that was released is 1.59.0. I updated the workspace and tried again, but unfortunately, still no success :frowning:
I can’t even connect using API access token:
Hey @PauloAFA,
The token is intended for the older API for now the OAuth option is the best way to go.
When you tried after updating did you make a new oauth credenital as it may need that.
It is possible that as it is Cloud we will need to do a quick update as well I will give it a quick test shortly.
The Webflow fields aren’t even appearing in my UI anymore, help @Jon! lol
Hey @jakemorrison,
Are you using the v1 or v2 node? I have just tested the v2 node locally and it appears to be working.
I’ve tried both node versions and I’m connected to Webflow via OAuth2 API.
On v1, I get the options to select the site name and collection; but I’m not able to select any fields (like the screenshot).
But on v2, nothing loads—not even the site name and collection.
Hey guys!
I’m having a similar problem with v2
Hi guys, I’m experiencing the exact same problem using the latest version on cloud. Is there any update on the resolution?
Hey, @Jon! Any updates?
@Jon @ria @aya @mariana-na any update? We haven’t been able to update any of our clients’ Webflow related automations and we’re running out of excuses to be honest… we’re spending EUR 1627.20 a year on this n8n plan and the whole purpose is to bring superpowers to our Webflow projects. We’re at a standstill. Please advise.
Hi everyone,
I’m sorry this issue has been draggring through a few versions - we’re looking into it and planing a fix for as soon as possible. Since we weren’t being able to recreate this it became hard to debugg. Will update you as soon as we have a fix in place.
Thank you for keeping posting details on this! :raised_hands:
:wave: This should be sorted out later today, the problem here is our Cloud offering has managed credentials so that you don’t need to worry about setting your own so with self hosted this node is currently all good but on Cloud I didn’t realise at the time we need to do the extra update.
I have created the new app on the Webflow side and will update the cloud team shortly, Once this change is in you will need to restart your n8n instances and create a new Webflow credential with Legacy disabled and you should be good to go.
Hi, Jon! Any updates?
I saw that you updated the app scopes, but as you can see, none of my workspaces are shown yet.
@Jon any update?
