Hi) I have a problem with adding another community node and cant find the button for searching a community node what I want to.
Are any opportunity to add another nodes of for Starter plan I can add only one node?
Thanks
Hey @dev.serdiuk hope all is good. Welcome to the community
You can search ALL community nodes here.
BUT…
only approved community nodes can be installed on the cloud version of n8n.
Hi @jabbson
Thank you for answer but I have no button on setting for adding or searching other nodes(
I have no opportunity to do the third step( As you cloud sow in my previous message , no way for searching via mu wokspace
How It could be solve?
Are you using self-hosted or cloud version of n8n?
Then this option is not available for you. As I stated in the first message - installing arbitrary community nodes is not allowed in the cloud version. Only approved nodes are allowed and they are already in the list.
If my response answered your question, kindly mark it as solution. Thanks.
Cheers
P.S.: info i shared is mentioned on this page
