Problem with an http request (JSON parameter need to be a valid JSON) . In variables
Guys, I hope you find it well.
I’m making a request on n8n and for some reason it’s not accepting my variables and it gives an error in the JSON.
First I was pulling them from an Excel, then now I created a SET node to try and see if it worked, but it doesn’t work.
I did a test in another workflow with the same request but without the variables (expressions) and it works.
Does anybody know how to solve this?
[https://aawz.app.n8n.cloud/workflow/PiOqX1TwqMZuibMc/executions/57]
“meta”: {
“instanceId”: “8f15dc730c58cd2eb5917ce235e3dee955c5e1e6d48924c721d3be25bba46505”
“nodes”: [
“parameters”: {
“method”: “POST”,
“url”: “https://crm.rdstation.com/api/v1/tasks?token=66534df919eb1d0012fec498”,
“sendHeaders”: true,
“headerParameters”: {
“parameters”: [
“name”: “accept”,
“value”: “application/json”
“name”: “content-type”,
“sendBody”: true,
“specifyBody”: “json”,
“jsonBody”: “={\n "task": {\n "date": "{{ $(‘Edit Fields’).item.json[‘Due Date’] }}",\n "deal_id": "{{ $(‘Edit Fields’).item.json.ID }}",\n "done": true,\n "hour": "{{ $(‘Edit Fields’).item.json.Hora }}",\n "notes": "{{ $(‘Edit Fields’).item.json.Notas }}",\n "subject": "{{ $json.Tipo }}",\n "type": "task"\n }\n}\n”,
“options”: {}
“id”: “aa6d7b0f-9bde-4b9c-a175-8de824b192d1”,
“name”: “Criando tarefa como concluida1”,
“typeVersion”: 4.1,
“position”: [
2040,
240
“connections”: {},
“pinData”: {}
n8n Version 1.41.1
Banco de dados (padrão: SQLite)
Configuração n8n EXECUTIONS_PROCESS
Executando n8n via (Docker, npm, n8n cloud, aplicativo de desktop)
I don’t know yet, I’m on trial.
Using just an excel and an http request
Operating system: Windows 11 Home Single Language, Versão 23H2, Compilação do SO 22631.3593
@mateus.silva , turn the whole JSON into the expression and remove the quotes and the double curly braces from where they are now. That is, it should look like this
    "task": {
      "date": $....,
      "deal_id": $...
Thus?
I did not work :confused:
[(https://aawz.app.n8n.cloud/workflow/PiOqX1TwqMZuibMc)](https://aawz.app.n8n.cloud/workflow/PiOqX1TwqMZuibMc)
I wanted to paste my workflow here to help. But I don’t think I managed.
PiOqX1TwqMZuibMc
type or paste code here
@mateus.silva , no, not like that. Take a look at my example again. The whole JSON has to be turned into an expression. That is, it has to be enclosed with double curly braces
  YOUR JSON GOES HERE
@ihortom unsuccessfully.
“task”: {
“date”: $(‘Google Sheets’).item.json[‘Due Date’],
“deal_id”: $(‘Edit Fields’).item.json.ID,
“done”: false,
“hour”: $(‘Google Sheets’).item.json[‘Hora due’],
“notes”: $(‘Google Sheets’).item.json.Notas,
“subject”: $(‘Google Sheets’).item.json.Tipo,
“type”: task
@mateus.silva , it’s a different error now. The HTTP Request node in the last workflow you shared has an extra space in between double curly braces and thus it is not a valid expression. Also, the word “task” is missing the quotes. I asked to remove the quotes from expressions only, not the regular string values.
{ {  // you have extra space between {{
  "task": {
    "date": $('Google Sheets').item.json['Due Date'],
    "deal_id": $('Edit Fields').item.json.ID,
    "done": false,
    "hour": $('Google Sheets').item.json['Hora due'],
    "notes": $('Google Sheets').item.json.Notas,
    "subject": $('Google Sheets').item.json.Tipo,
    "type": task   // it has to be "task", not just task
} }  // you have extra space between }}
