Problem with apollo.io
Hello, I have a problem with apollo.io I would like to call the API [for]
(https://api.apollo.io/api/v1/people/bulk_match) when I test the node, I have an error on json and I have this message
n8n apo1
it writes to me:
Unexpected non-whitespace character after JSON at position 9 (line 1 column 10)
and in terms of space I can’t delete it or at least I don’t see any
Could someone help me please?
THANKS
hello @Thim_Ber
That means your JSON is incorrect. Check the syntax with online tool, e.g. https://jsoneditoronline.org/
But the most common mistake is the comma after the last element, like:
  "key1": "value",
  "key2": "value",   <--- issue
