Hello, I’m just starting with n8n, and I’m having serious issues with the node for creating events in Google Calendar. I can’t get it to create the event on the date I specify. I used the expression {{$fromAI(“start_date”)}}, and although the correct date appeared in the description, it didn’t add the event to the calendar. I tried using the option to define it automatically through the model, but I got a request error. I’ve checked the calendar ID, Google authentication, replaced the node, specified it in the prompt, and I still can’t get past this issue.
Sorry if i miss anything, it´s the first time I post.
Thank to everyone.
Marti
“errorMessage”: “Bad request - please check your parameters”,
“errorDetails”: {},
“n8nDetails”: {
“time”: “28/2/2025, 18:28:10”,
“n8nVersion”: “1.79.3 (Cloud)”,
“cause”: {
“message”: “Bad request - please check your parameters”,
“timestamp”: 1740763690018,
“name”: “NodeApiError”,
“description”: “Invalid resource id value.”,
“context”: {},
“cause”: {
“message”: “400 - {"error":{"errors":[{"domain":"global","reason":"invalid","message":"Invalid resource id value."}],"code":400,"message":"Invalid resource id value."}}”,
“name”: “AxiosError”,
“stack”: “AxiosError: Request failed with status code 400\n at settle (/usr/local/lib/node_modules/n8n/node_modules/axios/lib/core/settle.js:19:12)\n at Unzip.handleStreamEnd (/usr/local/lib/node_modules/n8n/node_modules/axios/lib/adapters/http.js:599:11)\n at Unzip.emit (node:events:530:35)\n at endReadableNT (node:internal/streams/readable:1698:12)\n at processTicksAndRejections (node:internal/process/task_queues:82:21)\n at Axios.request (/usr/local/lib/node_modules/n8n/node_modules/axios/lib/core/Axios.js:45:41)\n at processTicksAndRejections (node:internal/process/task_queues:95:5)\n at invokeAxios (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/node-execution-context/utils/request-helper-functions.js:173:16)\n at proxyRequestToAxios (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/node-execution-context/utils/request-helper-functions.js:513:26)\n at Object.request (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/node-execution-context/utils/request-helper-functions.js:1145:50)\n at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/node-execution-context/utils/request-helper-functions.js:842:20\n at SupplyDataContext.requestOAuth2 (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/node-execution-context/utils/request-helper-functions.js:792:12)\n at SupplyDataContext.requestOAuth2 (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/node-execution-context/utils/request-helper-functions.js:1153:20)\n at SupplyDataContext.googleApiRequest (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Google/Calendar/GenericFunctions.js:38:16)\n at SupplyDataContext.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Google/Calendar/GoogleCalendar.node.js:280:40)\n at handleToolInvocation (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/node-execution-context/utils/get-input-connection-data.js:41:44)\n at DynamicStructuredTool.func (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/node-execution-context/utils/create-node-as-tool.js:78:35)\n at DynamicStructuredTool.call (/usr/local/lib/node_modules/n8n/node_modules/@langchain/core/dist/tools/index.cjs:113:22)\n at /usr/local/lib/node_modules/n8n/node_modules/langchain/dist/agents/executor.cjs:486:27\n at async Promise.all (index 0)\n at AgentExecutor._call (/usr/local/lib/node_modules/n8n/node_modules/langchain/dist/agents/executor.cjs:478:30)\n at AgentExecutor.invoke (/usr/local/lib/node_modules/n8n/node_modules/langchain/dist/chains/base.cjs:58:28)\n at ExecuteContext.toolsAgentExecute (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/nodes/agents/Agent/agents/ToolsAgent/execute.js:185:30)\n at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/nodes/agents/Agent/Agent.node.js:383:20)\n at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:627:19)\n at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:878:51\n at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:1211:20”,
“code”: “ERR_BAD_REQUEST”,
“status”: 400
- n8n version:- 1.79.3
- **Running n8n via n8n cloud
- **Operating system:**Win10
