Problem with form flow in production
Hello,
I have a flow that starts with a form submission and then an AI agent. The flow works well in testing, but in production it fails.
Has anyone had a siilar issue?
Version 1.99.1
Hey @saravalent
Can you please click on the form node so I can help and see the urls
Hello,
test: https://primary-production-bdbb.up.railway.app/form-test/09fe1fa3-13eb-49e2-93c1-987609c906ca
prod: Mantu: Sentiment Summary
does this help?
@saravalent
Thanks so when you fill the prod form what error you get exactly ?
Hi, the one in the screenshot, e node error
There’s a tool that your Workflow doesn’t like can you find out which one?
I think it’s the AI agent
I think it’s the agent node
