Problem with Formatting data
Hey,
Im trying to convert response received from nocoDB to structure accepted by quickChart. Im trying to format data in javascript but Im getting nulls…
Please can you check if you see any issues? Thank you for help!
Welcome to the community @bystry !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
I would advise using Set node instead. It is more straightforward. You do not need Code with custom scripting for that.
If you need to format date, you might want to use DateTime object from Luxon library. It’s very versatile and is more flexible than using standard Javascript Date object.
hello @bystry
the issue is that you have missed the json sub-property (e.g. instead of the data[i].date you will need to refer data[i].json.date)
the all() method will return item in the format
  "json": {
    "key": "value"
but in the UI it shows as
    "key": "value"
or you can fix it by simply replacing the 6th line with
var data = $input.all().map(x => x.json)
then it will remove the hidden json property from the object
thank you all for help! specially you @barn4k !
