Hey,
Firstly, thanks for being part of your community!
I am using n8n self-hosted on docker with nginx. I am trying to add credentials for Google calendar, but unfortunately I got stacked.
I made new credential: flameshot_screenshot - Imgur
I made a key for them: flameshot_screenshot - Imgur
I made new credentials in n8n with
3.1 Client ID: flameshot_screenshot - Imgur (tried also email)
3.2 Client Secret: flameshot_screenshot - Imgur (I copied this key and replace \n to new line)
When I click Sign in with Google, I got auth error: flameshot_screenshot - Imgur
Also when I am in calendar node, I cannot load my calendars:
I am new in n8n so I am sorry if I am making stupid mistake
Thank you very much in advance!
Welcome to the community @Shirobachi
Did you follow The instructions below?
Yes,
I mean, before I was using Service Account instead of OAuth . Now I changed all staff to OAuth but still I cannot sing in with Google…
I am not sure if it’s related, but on n8n callback url had no / after dev (on google console I added ofc)
I also use password on my page
ahh yes., the missing / is an issue. You need to set the env variable WEBHOOK_TUNNEL_URL=https://yoururl/
Edit:
WEBHOOK_TUNNEL_URL was deprecated, use WEBHOOK_URL instead.
RicardoE105:
WEBHOOK_TUNNEL_URL
Yeah, it’s working! Lovely, thanks!
The great @krynble has also created a PR to fix this automatically in the future:
master ← fix-webhook-url-slash
opened 09:16AM - 12 Aug 21 UTC
In case it's not present in the settings or env variables, we add it as it's exp… ected it'd be there.
Relates to community issue https://community.n8n.io/t/problem-with-google-calendar-credentials/7232
Hi Shirobachi,
Could you please tell me how you managed to use Service Account for Google Calendar ? I don’t seem to be able to do it (see my post about it )
Thanks!
