Problem with GoogleCalendar (update)
I can’t auto-update data in Google Calendar with AI.
this node is for updating an existing event in the calender, so you have to specify which one either manually, or create a new event.
Im not sure if you fetch all the events that update the one that you select with ai, but try it too.
ok, but i know that other guys also have this problem. on Github this issue has closed but it’s not working.
i need to automatic update an event when the client asks so i can’t paste the event ID
