Hello everyone
I have a beginner’s question ![]()
I’m using the MySQL Connector to write two values to a database. I’ve connected the database and can map the table. That’s good enough.
The table looks like this in MySQL:
I do the following in the MySQL Connector:
But now I get the following error message:
Unknown column ‘output’ in ‘SET’
sql: UPDATE intrest_rates SET output = intrest_rate_10 = ‘1.66%’, company_name = ‘1’ WHERE company_name = NULL, code: ER_BAD_FIELD_ERROR
Isn’t the query somehow wrong? Why is “output” in the query and why is company_name = NULL?
I’m kind of confused right now.
Thank you for your support.
Stefan
