Hello n8n Community,
I’m encountering an issue with the “Stop and Error” node in my workflow and need some guidance on how to resolve it.
Node type
n8n-nodes-base.stopAndError
Node version
1 (Latest)
n8n version
1.37.3 (Cloud)
Time
07/05/2024, 09:12:38
Stack trace
NodeOperationError: Limite de requests adicionais atingido (máximo de 1 tentativas) sem ter ao menos 70% de anúncios processados com sucesso. at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/StopAndError/StopAndError.node.js:91:15) at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:728:42) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:660:68 at processTicksAndRejections (node:internal/process/task_queues:95:5) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1062:20
- n8n version: 1.37.3
- **Database (default: SQLite):cloud
- **n8n EXECUTIONS_PROCESS setting (default: own, main):cloud
- Running n8n via (n8n cloud): cloud
- **Operating system:Mac OS - 14.2.1
