Hello Community !! I want to make a flow to communicate N8N with MS Onedrive, but based on the message you get to obtain the API credentials when you go to “Microsoft Application Registration Portal” you see:
-The ability to create applications outside of a directory is deprecated. To get your own directory, you can join the M365 developer program or sign up for Azure - Next, I have the problem that when creating the Azure free trial account, it does NOT show the fields to validate my phone number (+54…) and credit card, so if I move forward without completing this, I get the message “Not suitable for an Azure subscription”. I appreciate if anyone has had similar problems, and any help finding a solution to obtain the Onedrive API credentials to N8N.
- **n8n version:1.101.1
- Database (default: SQLite):
- Running n8n via (VPS-Docker):
- Operating system:
