## Describe the problem/error/question
When using the WhatsApp Business Cloud n…ode with dynamic values for the recipient phone number or text body, the workflow execution fails with the error "No execution data available."
The issue only occurs when using parameters in the recipient or text fields. If both values are hardcoded, the message sends successfully.
Things I’ve Tried (Still Getting the Error):
✅ Converted values to .toString() → Still fails.
✅ Added a "Set" node before the WhatsApp node → Same issue.
✅ Tried different combinations of fixed/dynamic values:
Fixed phone + dynamic text → ❌ Error
Dynamic phone + fixed text → ❌ Error
Fixed phone + fixed text → ✅ Works
✅ Copied and pasted the entire workflow into a new one → Same error.
The only way to get the message to send is if both the phone number and text body are hardcoded.
## What is the error message (if any)?
"errorMessage": "No execution data available",
"errorDetails": {},
"n8nDetails": {
"itemIndex": 0,
"runIndex": 0,
"time": "12/3/2025, 4:15:23 p.m.",
"n8nVersion": "1.82.1 (Cloud)",
"binaryDataMode": "filesystem",
"stackTrace": [
"ExpressionError: No execution data available",
" at Object.get (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/WorkflowDataProxy.js:310:31)",
" at Object.get (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/WorkflowDataProxy.js:1030:104)",
" at Proxy.eval (eval at getFunction (/usr/local/lib/node_modules/n8n/node_modules/@n8n/tournament/dist/FunctionEvaluator.js:14:22), <anonymous>:6:46)",
" at FunctionEvaluator.evaluate (/usr/local/lib/node_modules/n8n/node_modules/@n8n/tournament/dist/FunctionEvaluator.js:20:19)",
" at Tournament.execute (/usr/local/lib/node_modules/n8n/node_modules/@n8n/tournament/dist/index.js:43:31)",
" at evaluateExpression (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/ExpressionEvaluatorProxy.js:123:16)",
" at Expression.renderExpression (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Expression.js:238:70)",
" at Expression.resolveSimpleParameterValue (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Expression.js:217:34)",
" at Expression.getParameterValue (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Expression.js:300:25)",
" at RoutingNode.getParameterValue (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/routing-node.js:414:40)",
" at RoutingNode.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/routing-node.js:97:30)",
" at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:739:26)",
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:919:51",
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:1252:20"
## Please share your workflow/screenshots/recording
workflow:
"nodes": [
"parameters": {
"rules": {
"values": [
"conditions": {
"options": {
"caseSensitive": true,
"leftValue": "",
"typeValidation": "strict",
"version": 2
"conditions": [
"id": "bd3c7b33-e943-45b2-adb1-ca05dd488db1",
"leftValue": "={{ $json[\"Tipo de Pack\"] }}",
"rightValue": "PACK DE LEYES CERRADO",
"operator": {
"type": "string",
"operation": "equals",
"name": "filter.operator.equals"
"combinator": "and"
"conditions": {
"options": {
"leftValue": "",
"version": 2
"conditions": [
"rightValue": "PACK DE LEYES JUSTICIA",
"operator": {
"type": "string",
"id": "95ac9e72-2ace-401a-8067-8138ca558036"
"combinator": "and"
"conditions": {
"options": {
"leftValue": "",
"version": 2
"conditions": [
"id": "6373afa8-d87a-4b34-a016-dfda7b154a81",
"rightValue": "PACK DE LEYES AGENTE DE HACIENDA",
"operator": {
"type": "string",
"combinator": "and"
"conditions": {
"options": {
"leftValue": "",
"version": 2
"conditions": [
"id": "7fe15d68-4ad2-45b2-a8f4-97206c5e6e8a",
"rightValue": "Pack Personalizado",
"operator": {
"type": "string",
"combinator": "and"
"options": {}
"type": "n8n-nodes-base.switch",
"typeVersion": 3.2,
"position": [
-400,
180
"id": "effd5c02-4ad0-4eaf-ad40-076f3f56f32a",
"name": "Switch Tipo Pack"
"parameters": {
"operation": "send",
"phoneNumberId": "",
"recipientPhoneNumber": "={{ $json.Phone.toString() }}",
"textBody": "=Hola ",
"additionalFields": {}
"type": "n8n-nodes-base.whatsApp",
"typeVersion": 1,
"position": [
40,
500
"id": "a0c18ccd-cb54-445d-a780-2610a3f59a2d",
"name": "Pack PersO",
"webhookId": "55dcbc89-c55d-415b-85ea-1e248ca2e033",
"credentials": {
"whatsAppApi": {
"id": "",
"name": "WhatsApp account Adrian"
"parameters": {
"amount": 50
"type": "n8n-nodes-base.wait",
"typeVersion": 1.1,
"position": [
-180,
500
"id": "",
"name": "Wait10",
"webhookId": ""
"connections": {
"Switch Tipo Pack": {
"main": [
"node": "Wait10",
"type": "main",
"index": 0
"Pack PersO": {
"main": [
"Wait10": {
"main": [
"node": "Pack PersO",
"type": "main",
"index": 0
"pinData": {},
"meta": {
"instanceId": "5c431444819003241f8de37955f4075c96c60cff83a23fb628cc3eb4a130cd44"
⚠️ WARNING ⚠️ If you have sensitive data in your workflow (like API keys), please remove it before sharing.
## Share the output returned by the last node
"errorDetails": {},
"n8nDetails": {
"itemIndex": 0,
"runIndex": 0,
"time": "12/3/2025, 4:30:40 p.m.",
"stackTrace": [
## Debug info
### core
- n8nVersion: 1.82.1
- platform: docker (cloud)
- nodeJsVersion: 20.18.3
- database: sqlite
- executionMode: regular
- concurrency: 20
- license: community
### storage
- success: all
- error: all
- progress: false
- manual: true
- binaryMode: filesystem
### pruning
- enabled: true
- maxAge: 720 hours
- maxCount: 25000 executions
### client
- userAgent: mozilla/5.0 (windows nt 10.0; win64; x64) applewebkit/537.36 (khtml, like gecko) chrome/134.0.0.0 safari/537.36
- isTouchDevice: false
Generated at: 2025-03-12T23:21:17.862Z}
