I used the postgres-memory node connected to supabase in n8n and it functions with the first human message, but at the second human message, I get this error:
Error in sub-node ‘Postgres Chat Memory‘
Cannot use a pool after calling end on the pool
I have no idea how to solve this problem. I looked in all the settings in supabase and n8n..
See the attached image:
# Debug info
## core
- n8nVersion: 1.74.0
- platform: npm
- nodeJsVersion: 22.12.0
- database: postgres
- executionMode: regular
- concurrency: -1
- license: enterprise (production)
- consumerId: 5a5…
## storage
- success: all
- error: all
- progress: false
- manual: true
- binaryMode: memory
## pruning
- enabled: true
- maxAge: 336 hours
- maxCount: 10000 executions
## client
- userAgent: mozilla/5.0 (macintosh; intel mac os x 10_15_7) applewebkit/ (khtml, like gecko) chrome/ safari/
- isTouchDevice: false
Generated at: 2025-01-14T14:04:37.811Z
n8n
January 14, 2025, 2:09pm
2
n8n version:
Database (default: SQLite):
Operating system:
n8n version:
1.74.0
PostgreSQL - is a project in supabase
regular
npm - is hosted on render.
Operating system:
I work with windows and macOs
vpop
January 15, 2025, 11:40pm
5
This just started happening to me too after getting the latest update. Anyone figure out how to solve?
MattB
January 16, 2025, 5:26am
6
Dear @jan ,
Could you please have someone from the team check on this? Having the same issue on production flows, our AI Agents are failing unfortunately.
Seems urgent
I have the same issue hix
Hi guys
Can you tell me if this bug has been resolved?
I need this node to move forward with a project.
ria
January 16, 2025, 8:57am
9
Hi guys, good news, we got a fix for this ready to be released. Hopefully will go out this week still.
master ← backport-connection-pooling-to-postgres-v1
opened 11:51AM - 07 Jan 25 UTC
## Summary
This uses the pool manager for postgres v1, but additionally i… t also fixes the credential test for postgres which before would shut down the shared pool and lead to `Connection pool of the database object has been destroyed.` on any subsequent execution.
Taken from the [pg-promise docs](https://vitaly-t.github.io/pg-promise/index.html):
> Object db represents the Database protocol with lazy connection, i.e. only the actual query methods acquire and release the connection automatically. Therefore, you should create only one global/shared db object per connection details.
Thus it's not necessary to release connections manually. They are managed by pg-promise.
You can verify this using these queries and constructing a workflow that executes them once a second:
Lists all open connections per db, grouped by state.
```sql
SELECT
datname,
usename,
state,
COUNT(*)
FROM pg_stat_activity
WHERE backend_type = 'client backend'
GROUP BY datname, usename, state;
Long running query to simulated load.
```sql
SELECT
g.i,
pg_sleep(0.001) -- each row sleeps for 1ms
FROM generate_series(1, 1000) g(i);
By default the pool has a size of 10. If we need more then the next execution hangs until the next connection is free.
That limit is way too low.
I set it to 10_000 to test what happens if I ran out of the 100 connections my local postgres allows:
Also quickly after deactivating the workflow the pool was cleaned up and all 100 connections have been available again.
I would like to set it to unlimited for now, but that's not possible:
https://github.com/brianc/node-postgres/issues/1977
But for that reason I made it configurable in the credential.
## Related Linear tickets, Github issues, and Community forum posts
Fixes #12517
[NODE-2240](https://linear.app/n8n/issue/NODE-2240)
## Review / Merge checklist
- [x] PR title and summary are descriptive. ([conventions](../blob/master/.github/pull_request_title_conventions.md))
- [ ] ~[Docs updated](https://github.com/n8n-io/n8n-docs) or follow-up ticket created.~
- [ ] Tests included.
- [x] PR Labeled with `release/backport` (if the PR is an urgent fix that needs to be backported)
Sorry for this and thanks for your patience
thank you for your feedback, we hope to fix it ASAP as it affects the productions.
thanks again.
Same. Try to rolling back n8n version
dunx
January 17, 2025, 8:33am
14
which version are you using
ria
January 17, 2025, 10:18am
15
Hi everyone, we’ve just released the fix with version 1.75.1
If anyone can update and test again to see if it is resolved, we’d appreciate the feedback!
cjuarez
January 17, 2025, 11:30am
16
I have updated to 1.74.2, which is the latest available, and the error persists.
Not working for me
Edit: Could you please add an option to downgrade to 1.73.1? That version was working fine
ria
January 17, 2025, 1:18pm
18
Thanks for the feedback. We’re working on it!
For the meantime, if you’re on cloud and want to downgrade to version 1.73.1 please message our n8n support at support@n8n.io
Thanks for your patience in the meantime!
Thank you very much for being hands-on solving the problem. At the moment, I don’t have any production workflow affected, so I can use Window Buffer Memory while testing other workflows until you solve it. Thank you very much.
Seems to function now after the last update.
1.75.2 works!
Thanks for the great job!
