Problems with SplitInBatches and HTTP requests
I want to use the node for SplitInBatches to post Http requests like this.
I set the expression from input.
when I set Batch size equals 1 . it’s work。
but,when i set batch size lagger than 1 .it does not work .there is only first one of every batch is right.
How would I get this working?
My input is array like this.
Sounds like the same problem as described here:
Thanks for reply.
i change my node expression to this
the “Set” node :
when the workflow like this. it does work.
but i connect the node like this .it does not work.
In this case, is the problem that they are in different “runs”. The Set-Node did execute only once. The other nodes multiple times. So you have to then additionally also define the run index 0 like this to say specifically that you want the data of the first item of the first run:
{{ $item(0, 0).$node["Set"].json["token"] }}
You can find the documentation here:
According to your method, the problem has been solved. Thank you!
