Problems with Telegram Trigger not detecting messages
I am new to n8n and a want to replicate some worklfows I have seen on Youtube, but am stuck with the first node, a telegramm trigger
I created a telegram bot, and retrieved the api key. I created a node and added the credentials. The check with the credential was ok.
I first had bad request error messages , so I created a new container with the command
docker run --name n8n-tunnel -p 0.0.0.0:5678:5678 -v n8n_data:/home/node/.n8n docker.n8n.io/n8nio/n8n start --tunnel
which showed a tunnel url ( I do not know what to do with it)
Now, the node does not show the bad request error, but when I click on it it says
Listening for test event
But no message is received when I send a message from my telegramm app on my Iphone
there is no error message, just listening and not getting my message
All tutorials I see on youtube seem so easy, and never adress this problem
no output
  • n8n version: 1.75.2
  • n8n EXECUTIONS_PROCESS setting (default: own, main):default
  • Running n8n via (Docker, npm, n8n cloud, desktop app):Docker
  • Operating system: Mac Os Sequoia 15.2
I think Telegram requires a SSL Certificate, otherwise it won’t work
I thought that the problem would be solved by setting the option
start --tunnel
but honestly i have no idea what this tunnel is doing.
I use telegramm bots for my locl homeassistant and iobroker instances, and for these it works.
i have no idea how the communication flow is working here
Hi, i have the same problem when i upgrade for the new version, did you solve it ?
Thanks !
No, not so far. I do not know enough about how this tunnel should work. In my opinion it should open a socket to the telegramm servers, so that the connection is initiated by n8n and not by telegramm. But i am not sure about this and where to find the relevant docs.
I now have a liitle better understanding of how this should wortk.
Basicvall n8n creates a webhook. When I check my telegram bot with the request
https://api.telegram.org/bot/getWebhookinfo I see the webhook
The domain part of this url equals the tunnel url in my n8n instance.
But nothing else happens. I do not see any logs, nor do I receive my messages that I sent to the Bot.
May or may not be relevant, but it appears in my case I was suffering the same syptoms. However in closer inspection of the webhook created througth --tunnel it is the webhook that doesnt connect. Goes to 503 bad gateway timeout. I am guerssingh i have to solve that before anything that requires it will work. Maybe its the same for you guys?
I now have another message , after making a new install on a new machine.
in the logs of n8n i see the following
Waiting for tunnel …
Tunnel URL: https://blabla-blabla.hooks.n8n.cloud/
but then i see
connection refused: hooks.n8n.cloud:44517 (check your firewall settings)
i changed the port in the docker compose fie to pint externally to 5679, but I do not think that thos might be a problem
Thanks for the info. Can you please tell me how you figured this out? Where to look, what to check to simulate the findings?
Ok guys. After few days with the same problem I solved it.
How it works in my case.
For tunnel I’m using Ngrok
Here’s my run bat file
@echo off
docker stop n8n
docker rm n8n
docker run -d ^
  -p 8443:8443 ^
  -v n8n_data:/home/node/.n8n ^
  -e N8N_HOST=urladdress.ngrok-free.app ^
  -e N8N_PROTOCOL=https ^
  -e N8N_PORT=8443 ^
  -e WEBHOOK_TUNNEL_URL=https://urladdress.ngrok-free.app ^
  -e NODEJS_PREFER_IPV4=true ^
  -e N8N_LOG_LEVEL=debug ^
  -e N8N_LOG_FILE_LOCATION=/home/node/.n8n/logs/n8n.log ^
  --name n8n ^
ngrok http --url=urladdress.ngrok-free.app 8443
