Progress is not showing
i worked through those topics but still they are not marked as done for the progress
Any clues?
Does logout/login help?
nope doesn’t help sadly
If logout/login didn’t move it, the completion callback isn’t reaching the academy at all, so the tick stays hollow no matter how many times you revisit the lesson. Three things worth checking, in this order: that you’re signed in to the academy itself with the same email as your community account (a mismatch silently tracks progress on a separate account), that third-party cookies and content blockers aren’t blocked for the academy domain (those commonly kill the per-lesson completion call), and then a hard refresh of the course outline after finishing a lesson - the tick is written server-side but the outline page caches.
It’s a recurring report for the interactive hands-on lessons in particular, so you’re not doing anything wrong. If one specific lesson still refuses to tick after that, name the course and lesson and ask the team - re-triggering grading on the account isn’t something you can do from the UI.
