Project folders
Hey would be great if you can add some sort of feature like the project folders.
To be honest with you personally I don’t even need the share function, just the ability to put the right workflow in the right project.
I know that there are tags, but they are not super useful (not me personally) and a folders feature would be much more beneficial.
and even though sometimes I want to break my monitor because of a simple issue that gets fixed by duplicating the same node lol
N8N is great!
Hi @Vasislav
in 1.85 we finally got the folders. So you probably just need an update :wink:
Interesting, Because I don’t see the update notification
Hi, this is probably because 1.85:x is still next release. I guess update notifications go only out for update on stable release which is still 1.84.x
Yes it shows for latest indeed.
To be honest I never use latest or next tags as they can result in unwanted version updates. :roll_eyes:
Makes sense
