Pushcut issue
Hi guys.
Anyone any experience with pushcut ?
I have a shortcut working (Send Message2) on IOS. It is set to auto run and send text to 07861----- with a default message.
I have in Pushhcut app the following:
MyNotifications = Enabled
NOTIFICATION = Blank
ACTIONS Add Action = Blank
Default Action = Send Message2
Send Message2 shows under Shortcut and server Shortcut Shows
If I click test Notification
I get the sound but no text sent.
If I add a title it appears a notification appears and the sms is sent.
Testing from n8n gives the same results.
If I add input and title I get a prompt and click on it the test is sent with the input.
If I only send input the shortcut does not run.
To summarise it does not work unless the is a title or text value.
This obviously is not automated as I have to press on the popup to work. What am I missing here please. ???
Hey @Steve_Warburton
I am a bit confused on this one, are you saying that n8n is working the same as the pushcut app and is only sending a message when there is a title?
yes.
