When I run Python code node and print things to the console, nothing is printed in the console. I only see error messages or if something was returned it is returned there.
I copied the output of the HTML5 node into my local Python notebook and pretty quickly parsed the html in that environment however cannot for the life of me figure out what is happening in n8n because there is no console log.
If I try returning something instead of printing it and it is not what n8n expects as the output then it doesnt show me what was actually returned which is very frustrating for debugging. I’m basically guessing what my output was when I get an error.
I have a Gmail trigger that pulls email data from a specific sender, specific HTML elements are selected with an HTML5 block and that HTML is returned in JSON format. Then I am trying to use a Python code block to parse this html data into a dataframe then into a structured json format.
I was very much surprised by this one as well, I could have sworn this worked in past previews. Even if not, this seems like a bug to me, so I’ve added this to the engineering team’s backlog for a closer look and a fix.
That said, when using print you would still see output in your server logs. So when running the below example workflow including print(...) you should see the output in your terminal:
How to update to the newest version? I tried to update by clicking on the “1 Update” dialog box at the bottom left of the workflow screen, then click “How to update n8n” which brings me to a login screen when then brings me back to where I started?
