Python module 'requests' not found error
I add python code node but I can’t run it. I have just added import requests, the node return an error:
ModuleNotFoundError: No module named 'requests' at PythonSandbox.getPrettyError
  • n8n version: 1.54.4
  • n8n EXECUTIONS_PROCESS setting (default: own, main): own, main
  • Operating system: Ubuntu 20.04 LTS
hello @tungn1027
python module does not support requests library. Use the HTTP requests node for that
But according to list of supported packages requests library is currently supportet by Pyodide. It should work, shouldn’t it?
As far as I get it, they are optional packages which should be loaded via pyodide.loadPackage()
Mmh, then I’m getting an error telling me pyodide has no attribute loadPackage.
I suppose it’s because they should be loaded from the backend side. So you can’t load any additional packages for pyodide. Just use the HTTP node for requests instead
Yes, using the HTTP node is my current workaround but since I’m migrating a python based backend to n8n it would be nice to just copy over my scraping functions without adapting them and splitting them up into multiple nodes.
The confusion here is Pyodide added Requests from 0.25.0 and we use version 0.23.4 which doesn’t support it. I will see if we can get this updated at some point.
