Hi,
Im using execute command to run python script, works well as expected, but i didn’t find way to dyanmically get stdout from execute command node.
I have to wait for the execute command pass to get the stdout.
have you an idea ?
regards,
Hi,
have you an idea ?
regards,
Hey @Jeremy_Bepoix, I am not sure I fully understand the question. What does your Execute Command output look like and what would you like it to be instead?
My execute command looks like :
py -3.9 path/to/myscript.py
myscript.py looks like :
<code stuff>
print('exemple_print_a')
<code stuff>
print('exemple_print_b')
<code stuff>
print('exemple_print_c')
output looks good :
exit : 0, stderr:0, stdout:"exemple_print_a, exemple_print_b, exemple_print_c"
BUT, i have to wait the end of execute command process to get all print.
isn’t dynamic
So you’d like the Execute Command node to trigger the workflow execution each time it prints something to stdout? That’s unfortunately not how the node works, it would wait for the respective command to finish.
If you control the script you could consider sending a simple webhook to n8n’s webhook node instead each time it would usually print something. That way, you could trigger a new workflow execution immediately for each webhook.
okay, i’ll try another way.
thanks
Hi @Jeremy_Bepoix ,
can you explain about the settings - how do you run your python scripts by the way you described above?
I mean “py -3.9 path/to/the/script”? Is there some manual on how to do the same? I am trying to run the run the script by a schedule. Still no success.
I tried a few variants:
python3 /home/username/project_65970/get_bd_date.py
or
/usr/lib/python3.6/python3 /home/username/project_65970/get_bd_date.py
Every time I receive the error message:
/bin/sh: /usr/lib/python3.6/python3: not found
or
/bin/sh: python3: not found
Hi @Nicolay_Vasiliev, n8n would need to have access to Python in order to run any scripts.
Depending on how you have deployed n8n there are different ways to achieve this. You could for example create a custom Docker image for n8n that installs Python (of you are using Docker in the first place).
Hi @MutedJam,
thanks for your response!
I use n8n via Docker Compose. I have found the topic with a similar context and I still don’t understand which way I need to use exactly
So to use Python on my own instance I am using a Dockerfile like this:
FROM n8nio/n8n:latest
ENV PYTHONUNBUFFERED=1
RUN apk add --update --no-cache python3 curl
RUN python3 -m ensurepip
RUN pip3 install --no-cache --upgrade pip setuptools
RUN pip3 install speedtest-cli
My docker-compose.yml file in the same directory then defines n8n like so:
services:
n8n:
build: .
restart: unless-stopped
environment:
Now when I run docker pull n8nio/n8n:latest && docker compose build I am building a custom version of n8n including Python:
Hi @MutedJam ,
Thank you very much for such detailed explanation ![]()
