Query Parameters not working with Postgres Connection
I just started working with n8n yesterday. I’m having an issue with the query parameters with a Postgres connection. I set the query parameter in the edit fields node and it appears to be passing into the Postgres node as input parameters. In the query parameter I tried with single quotes and without but no results are returned from the query. If I type out the full sql without the query param it works fine. I have tried everything I can think of. Please help!
Hey @david.middleton ,
Can you please try this workflow. I have made some changes to it.
What changes I have made?
  • When you are setting the value in set node there is no need to add the quotes to the value, so i have removed those
  • instead of using the parameter option in postgres node, I directly link the trucknumber in the query,
I believe it should work now for you.
Sudhanshu Sharma
That worked! Thanks so much for your help!
