Hello.
Here is a simplified example of my workflow for processing data from Google Sheets to Google Sheets. First, I use Get Row, and the result is 300 rows. I use a loop Node to process 3 rows per batch. Sometimes, the OpenAI HTTP request returns empty content or “NA”. If this happens, I want it to be processed again. Ideally, only retry for 3 times.
I’ve been reading some old threads But I still can’t make it happen. Below is my example flow. Thanks
