Hi guys I and trying to use the AI feature in the n8n, I am trying to build a RAG Question and answer chain by using the n8n feature and Qdrant vector database.
Here is a full picture of my current workflow, basicly I create a vector dabase qdrant server and wanna the it use the information in the vector database
In addtion, I add the data in to the qdrant database by following the instruction on Langchain
langchian Qdrant
So the format is like this:
Document( metadata ={} , page_content)
Basicly I meet two problem.
I have try both format with meta data or without metadata in Qdrant by example like this:
The vector tore retrier seem like only return the meta data part:
I assume it do not return any useful information to the RAG chian? So how to build a right vector db by using Qdrant.
Also in the RAG chain, it seems like not reading any information from the chain. Not sure how to set the prompting or the prompt to refine the answer in this case
Therefore, I want to ask for how to properly build a RAG in n8n with own vector database.
- n8n version: 1.31.1
- Database (default: SQLite):
- Running n8n via (Docker, npm, n8n cloud, desktop app): npm
- Operating system: Linux
