I am trying to upload the video which I downloaded earlier from Google Drive, but I am struggling with that, what is the correct way to do it? all my trials ends with error like:
Problem in node ‘Upload a video‘
This operation expects the node’s input data to contain a binary file ‘[object Object]’, but none was found [item 0]
What I tried:
{{ $(‘Download a file’).item.binary.BinaryFile.data}}
{{ $(‘Download a file’).item.binary.BinaryFile}}
{{ $(‘Download a file’).item.binary}}
nothing of them worked.
"nodes": [
"parameters": {
"pollTimes": {
"item": [
"mode": "everyMinute"
"triggerOn": "specificFolder",
"folderToWatch": {
"__rl": true,
"value": "1MZyIWJhUBSs79co63-7vNWiV8eJI-v46",
"mode": "list",
"cachedResultName": "N8N",
"cachedResultUrl": "https://drive.google.com/drive/folders/1MZyIWJhUBSs79co63-7vNWiV8eJI-v46"
"event": "fileCreated",
"options": {}
"id": "1abfba72-83a5-4ef5-9efb-d46d9dba7d0d",
"name": "Google Drive Trigger",
"type": "n8n-nodes-base.googleDriveTrigger",
"position": [
0,
170
"typeVersion": 1,
"credentials": {
"googleDriveOAuth2Api": {
"id": "QLWXMsaCoFht5bbl",
"name": "Google Drive account"
"parameters": {
"authentication": "oAuth2",
"operation": "download",
"fileId": {
"__rl": true,
"mode": "",
"value": "={{ $json.id || $json.data[0].id }}"
"binaryPropertyName": "BinaryFile",
"options": {}
"id": "d820ac57-38b4-415b-90c4-56a22bc73224",
"name": "Download a file",
"type": "n8n-nodes-base.googleDrive",
"position": [
220,
170
"retryOnFail": true,
"typeVersion": 1,
"waitBetweenTries": 5000,
"credentials": {
"parameters": {
"jsCode": "// Loop over input items and add a new field called 'myNewField' to the JSON of each one\n\nreturn JSON.parse($input.first().json.candidates[0].content.parts[0].text)"
"type": "n8n-nodes-base.code",
"typeVersion": 2,
"position": [
1100,
-80
"id": "16bb2536-5449-4b1e-a5ea-3f2e7569ed00",
"name": "Parse Gemini Results",
"notesInFlow": true,
"notes": "parses for every platform"
"parameters": {
"method": "POST",
"url": "https://api.upload-post.com/api/upload",
"sendHeaders": true,
"headerParameters": {
"parameters": [
"name": "Authorization",
"value": "Apikey eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJlbWFpbCI6Im1hc3NleWFtMTk5OEBnbWFpbC5jb20iLCJleHAiOjQ5MDYwMjk5MTcsImp0aSI6IjUyZjRmN2RmLWZlNDQtNDcyYy1iMWRiLTg0Yzc5NWI1ZTFlMyJ9.nnpnuUU3krb4wVfPejrGKaaA0QRCu1RUsQncodIecNM"
"sendBody": true,
"contentType": "multipart-form-data",
"bodyParameters": {
"parameters": [
"name": "title",
"value": "={{ $('Parse Gemini Results').item.json.tiktok.caption }}\n"
"name": "platform[]",
"value": "youtube"
"parameterType": "formBinaryData",
"name": "video",
"inputDataFieldName": "data"
"name": "user",
"value": "masseyam1998"
"options": {}
"id": "6f032190-8b74-48e1-bfe7-ef7c3c2408e0",
"name": "Upload Video and Description to Tiktok",
"position": [
1760,
-180
"typeVersion": 4.2,
"notes": "Generate in upload-post.com the token and add to the credentials in the header-> Authorization: Apikey (token here)"
"parameters": {
"resource": "video",
"operation": "upload",
"title": "Testing",
"regionCode": "EG",
"categoryId": "10",
"binaryProperty": "={{ $('Download a file').item.binary.BinaryFile}}",
"options": {
"description": "={{ $('Parse Gemini Results').item.json.tiktok.caption }}"
"type": "n8n-nodes-base.youTube",
"typeVersion": 1,
"position": [
2280,
80
"id": "28499614-94e9-44b1-812e-513a0d1b991c",
"name": "Upload a video",
"credentials": {
"youTubeOAuth2Api": {
"id": "pmH9BeiuuPw1vCEk",
"name": "YouTube account"
"parameters": {
"operation": "sendAndWait",
"chatId": "1350863880",
"message": "=Tiktok Generated Caption:\n{{ $('Parse Gemini Results').item.json.tiktok.caption }}\n\n",
"approvalOptions": {
"values": {
"approvalType": "double"
"options": {}
"type": "n8n-nodes-base.telegram",
"typeVersion": 1.2,
"position": [
1320,
-180
"id": "8d245a4e-c288-4beb-ac3a-a7784042fdbf",
"name": "Send a text message",
"webhookId": "6133e5f3-73f0-425b-914b-57e72ad17a90",
"credentials": {
"telegramApi": {
"id": "jRe73mMSgnzkSaS5",
"name": "Telegram account"
"parameters": {
"conditions": {
"options": {
"caseSensitive": true,
"leftValue": "",
"typeValidation": "strict",
"version": 2
"conditions": [
"id": "3380d8a8-3941-47ae-9699-229da11e94a0",
"leftValue": "",
"rightValue": "",
"operator": {
"type": "string",
"operation": "equals",
"name": "filter.operator.equals"
"combinator": "and"
"options": {}
"type": "n8n-nodes-base.if",
"typeVersion": 2.2,
"position": [
1540,
-180
"id": "2571fb57-eec3-4a78-9484-2df21ae51464",
"name": "If1"
"parameters": {
"title": "Testing direct upload",
"regionCode": "EG",
"categoryId": "17",
"options": {}
"typeVersion": 1,
"position": [
660,
-180
"id": "03ae3b4b-c78f-4fd4-adff-4bf7acb2ae43",
"name": "Upload a video1",
"credentials": {
"parameters": {
"method": "POST",
"url": "https://generativelanguage.googleapis.com/v1beta/models/gemini-2.0-flash:generateContent",
"parameters": [
"name": "x-goog-api-key",
"value": "AIzaSyBvGPwqRK-k18zEENF1k28ymzxTVTUr1BE"
"name": "="
"sendBody": true,
"specifyBody": "json",
"jsonBody": "={\n \"contents\": [\n {\n \"parts\": [\n {\n \"file_data\": {\n \"file_uri\": \"https://www.youtube.com/watch?v={{ $json.uploadId }}\"\n }\n },\n {\n \"text\": \"I will post this video on social media tiktok,instagram and facebook. please generate suitable captption for each platform along with some hashtages\"\n }\n ]\n }\n ],\n \"generationConfig\": {\n \"responseMimeType\": \"application/json\",\n \"responseSchema\": {\n \"type\": \"ARRAY\",\n \"items\": {\n \"type\": \"OBJECT\",\n \"properties\": {\n \"tiktok\": {\n \"type\": \"OBJECT\",\n \"properties\": {\n \"caption\": { \"type\": \"STRING\" },\n \"tags\": {\n \"type\": \"ARRAY\",\n \"items\": { \"type\": \"STRING\" }\n }\n },\n \"propertyOrdering\": [\"caption\", \"tags\"]\n },\n \"facebook\": {\n \"type\": \"OBJECT\",\n \"properties\": {\n \"caption\": { \"type\": \"STRING\" },\n \"tags\": {\n \"type\": \"ARRAY\",\n \"items\": { \"type\": \"STRING\" }\n }\n },\n \"propertyOrdering\": [\"caption\", \"tags\"]\n },\n \"instagram\": {\n \"type\": \"OBJECT\",\n \"properties\": {\n \"caption\": { \"type\": \"STRING\" },\n \"tags\": {\n \"type\": \"ARRAY\",\n \"items\": { \"type\": \"STRING\" }\n }\n },\n \"propertyOrdering\": [\"caption\", \"tags\"]\n }\n },\n \"propertyOrdering\": [\"tiktok\", \"facebook\", \"instagram\"]\n }\n }\n }\n}",
"options": {}
"typeVersion": 4.2,
"position": [
880,
-180
"id": "724aa423-e05e-4ffa-8de6-eb005ace51b4",
"name": "Process the video and generate content1"
"parameters": {
"operation": "delete",
"videoId": "={{ $('Upload a video1').item.json.uploadId }}",
"options": {}
"typeVersion": 1,
"position": [
1100,
-280
"id": "db6e27e1-1ed3-475f-90fe-0f8c88fe213f",
"name": "Delete a video",
"credentials": {
"parameters": {
"values": {
"options": {}
"typeVersion": 1.2,
"position": [
1320,
20
"id": "88375bce-c0c5-4433-b446-7a9038d4df96",
"name": "Send a text message1",
"credentials": {
"telegramApi": {
"parameters": {
"conditions": {
"options": {
"leftValue": "",
"version": 2
"conditions": [
"leftValue": "={{ $json.data.approved }}",
"rightValue": "",
"operator": {
"type": "boolean",
"operation": "true",
"singleValue": true
"combinator": "and"
"options": {}
"typeVersion": 2.2,
"position": [
1480,
-40
"id": "e84daf9a-4938-4825-9021-6b7a539f77cf",
"name": "If2"
"connections": {
"Google Drive Trigger": {
"main": [
"node": "Download a file",
"type": "main",
"index": 0
"Download a file": {
"main": [
"node": "Upload a video1",
"type": "main",
"index": 0
"Parse Gemini Results": {
"main": [
"node": "Send a text message",
"type": "main",
"index": 0
"node": "Send a text message1",
"type": "main",
"index": 0
"Send a text message": {
"main": [
"node": "If1",
"type": "main",
"index": 0
"If1": {
"main": [
"node": "Upload Video and Description to Tiktok",
"type": "main",
"index": 0
"Upload a video1": {
"main": [
"node": "Process the video and generate content1",
"type": "main",
"index": 0
"Process the video and generate content1": {
"main": [
"node": "Delete a video",
"type": "main",
"index": 0
"node": "Parse Gemini Results",
"type": "main",
"index": 0
"Delete a video": {
"main": [
"Send a text message1": {
"main": [
"node": "If2",
"type": "main",
"index": 0
"If2": {
"main": [
"node": "Upload a video",
"type": "main",
"index": 0
"pinData": {
"Google Drive Trigger": [
"parents": [
"lastModifyingUser": {
"displayName": "Mohamed Abdullah",
"kind": "drive#user",
"me": true,
"permissionId": "15765030077149778855",
"emailAddress": "[email protected]",
"photoLink": "https://lh3.googleusercontent.com/a/ACg8ocIeMYUAUeJ3W3qVYWqg3TlG91Rm0_34fsmcQAL2HmQ2rh2bVCFP=s64"
"owners": [
"me": true,
"permissions": [
"kind": "drive#permission",
"id": "15765030077149778855",
"type": "user",
"role": "owner",
"photoLink": "https://lh3.googleusercontent.com/a/ACg8ocIeMYUAUeJ3W3qVYWqg3TlG91Rm0_34fsmcQAL2HmQ2rh2bVCFP=s64",
"deleted": false,
"pendingOwner": false
"spaces": [
"drive"
"capabilities": {
"canAcceptOwnership": false,
"canAddChildren": false,
"canAddMyDriveParent": false,
"canChangeCopyRequiresWriterPermission": true,
"canChangeItemDownloadRestriction": true,
"canChangeSecurityUpdateEnabled": false,
"canChangeViewersCanCopyContent": true,
"canComment": true,
"canCopy": true,
"canDelete": true,
"canDisableInheritedPermissions": false,
"canDownload": true,
"canEdit": true,
"canEnableInheritedPermissions": true,
"canListChildren": false,
"canModifyContent": true,
"canModifyContentRestriction": true,
"canModifyEditorContentRestriction": true,
"canModifyOwnerContentRestriction": true,
"canModifyLabels": false,
"canMoveChildrenWithinDrive": false,
"canMoveItemIntoTeamDrive": true,
"canMoveItemOutOfDrive": true,
"canMoveItemWithinDrive": true,
"canReadLabels": false,
"canReadRevisions": true,
"canRemoveChildren": false,
"canRemoveContentRestriction": false,
"canRemoveMyDriveParent": true,
"canRename": true,
"canShare": true,
"canTrash": true,
"canUntrash": true
"permissionIds": [
"videoMediaMetadata": {
"width": 1280,
"height": 686,
"durationMillis": "192879"
"linkShareMetadata": {
"securityUpdateEligible": false,
"securityUpdateEnabled": true
"downloadRestrictions": {
"itemDownloadRestriction": {
"restrictedForReaders": false,
"restrictedForWriters": false
"effectiveDownloadRestrictionWithContext": {
"kind": "drive#file",
"id": "16_kNAfGq3f0D1Pe8_BzdbKDaFpMnCCPP",
"name": "44- Solid Principles | Implement Interface Segregation Principle | How we implement ISP for animal.mp4",
"mimeType": "video/mp4",
"starred": false,
"trashed": false,
"explicitlyTrashed": false,
"version": "8",
"webContentLink": "https://drive.google.com/uc?id=16_kNAfGq3f0D1Pe8_BzdbKDaFpMnCCPP&export=download",
"webViewLink": "https://drive.google.com/file/d/16_kNAfGq3f0D1Pe8_BzdbKDaFpMnCCPP/view?usp=drivesdk",
"iconLink": "https://drive-thirdparty.googleusercontent.com/16/type/video/mp4",
"hasThumbnail": true,
"thumbnailLink": "https://lh3.googleusercontent.com/drive-storage/AJQWtBMAojdD89fphJKiBeDw20Qqo5G3VtPzNurNXnPVV2NX1iPTcQkY_T8eDKGgP7npViXyvJ__skliLkVTS1NISHUd4AMmMSwjUDD3p7VrWNXGJz4=s220",
"thumbnailVersion": "1",
"viewedByMe": true,
"viewedByMeTime": "2025-07-13T17:14:16.292Z",
"createdTime": "2025-07-13T17:14:16.292Z",
"modifiedTime": "2023-03-27T20:15:01.000Z",
"modifiedByMeTime": "2023-03-27T20:15:01.000Z",
"modifiedByMe": true,
"shared": false,
"ownedByMe": true,
"viewersCanCopyContent": true,
"copyRequiresWriterPermission": false,
"writersCanShare": true,
"originalFilename": "44- Solid Principles | Implement Interface Segregation Principle | How we implement ISP for animal.mp4",
"fullFileExtension": "mp4",
"fileExtension": "mp4",
"md5Checksum": "81cb8f1804efd8571c53f288c45c0bc0",
"sha1Checksum": "ace9e34c208d9888dd5cb3077ad517cf44aed575",
"sha256Checksum": "379280d2837d5d559b6f9f4481ca1c38253288774baafb2d6bc12435f479a503",
"size": "5602116",
"quotaBytesUsed": "5602116",
"headRevisionId": "0B0aPraeJjI0idGFSazRKbm9Ba2grM1NjdWFtWnR6ekxHNFRBPQ",
"isAppAuthorized": false,
"inheritedPermissionsDisabled": false
"Parse Gemini Results": [
"tiktok": {
"caption": "Master the Interface Segregation Principle! 👨💻 Learn how to apply this key concept in software design with a clear and simple example. #coding #softwareengineering #interfacesegregation #solidprinciples #typescript",
"tags": [
"#coding",
"#softwareengineering",
"#interfacesegregation",
"#solidprinciples",
"#typescript"
"facebook": {
"caption": "Unlock the power of the Interface Segregation Principle! This video breaks down how to implement ISP in your software designs. Learn the key to creating flexible, maintainable code. #softwaredesign #codingtips #interfaces #programming #goodcode",
"tags": [
"#softwaredesign",
"#codingtips",
"#interfaces",
"#programming",
"#goodcode"
"instagram": {
"caption": "Level up your coding skills! 🚀 Discover the Interface Segregation Principle and build better software. #codinglife #softwaredeveloper #programmingconcepts #interfacesegregationprinciple #cleancode",
"tags": [
"#codinglife",
"#softwaredeveloper",
"#programmingconcepts",
"#interfacesegregationprinciple",
"#cleancode"
"Upload a video1": [
"uploadId": "_zoZkqXe4Uc"
"Process the video and generate content1": [
"candidates": [
"content": {
"parts": [
"text": "[\n {\n \"tiktok\": {\n \"caption\": \"Interface Segregation Principle explained with simple example\",\n \"tags\": [\n \"#isp\",\n \"#solid\",\n \"#principle\"\n ]\n },\n \"facebook\": {\n \"caption\": \"Interface Segregation Principle explained with simple example\",\n \"tags\": [\n \"#isp\",\n \"#solid\",\n \"#principle\"\n ]\n },\n \"instagram\": {\n \"caption\": \"Interface Segregation Principle explained with simple example\",\n \"tags\": [\n \"#isp\",\n \"#solid\",\n \"#principle\"\n ]\n }\n }\n]"
"role": "model"
"finishReason": "STOP",
"avgLogprobs": -0.14486335305606618
"usageMetadata": {
"promptTokenCount": 56315,
"candidatesTokenCount": 153,
"totalTokenCount": 56468,
"promptTokensDetails": [
"modality": "TEXT",
"tokenCount": 59
"modality": "AUDIO",
"tokenCount": 5760
"modality": "VIDEO",
"tokenCount": 50496
"candidatesTokensDetails": [
"modality": "TEXT",
"tokenCount": 153
"modelVersion": "gemini-2.0-flash",
"responseId": "vCl0aM_WHqGThMIPgeLqmQU"
"Send a text message1": [
"data": {
"approved": true
"meta": {
"instanceId": "7de3c4d412e7b907d57466e5b89eba34047904247ae1b2abcd31142c1752015a"
## Share the output returned by the last node
- **n8n version:** 1.102.2
- **Database (default: SQLite):** Postgres
- **n8n EXECUTIONS_PROCESS setting (default: own, main):** default
- **Running n8n via (Docker, npm, n8n cloud, desktop app):** Docker
- **Operating system:** Linux
