Questions about User Management system
Hi,
I have a couple of questions about the new User Management System:
  1. Can an instance have multiple owners? if not, do you have a plan to implement this feature in near future?
  2. Can owner share workflows across multiple members? If not do you have a plan to implement it?
Thanks
Hi @jellybean, right now only one owner is officially supported.
For sharing there are workarounds but they’d put your database in an unsupported state. @pemontto provided a great workflow to help with this which you can check out here:
As for plans to implement this: Yes, improvements to the user management functionality (and especially sharing of workflows/credentials) are on our to-do list. I don’t have an ETA though I am afraid.
Thank you very much for your answer.
You’re most welcome, sorry I didn’t have any better news here
No it’s totally okey.
Btw… If I share my owner user with a few people, can we login and work with n8n simultaneously?
Yes, that’s no problem at all :+1:
Just make sure that the people do not work on the same workflow at the same time. Because then they would overwrite the work of each other.
