n8n Scaling Mode Setup Instructions
Setting Up n8n in Queue Mode
This guide will help you set up a scaled version of n8n using Redis as a mediator and a PostgreSQL database to share workflow information between the main instance and worker instances.
Prerequisites
Install Docker
Ensure Docker is installed on your system. If not, install it from Docker’s official website.
Pre-checks
Before proceeding, stop any existing instances of PostgreSQL, Redis, or n8n running on your local machine using the following command:
sudo systemctl stop
Steps to Set Up n8n in Queue Mode
- Create a Docker Network
docker network create n8n
- Create the queue.env File
Create a new file named queue.env to store the required environment variables:
DB_TYPE=postgresdb
DB_POSTGRESDB_DATABASE=postgres
DB_POSTGRESDB_HOST=n8n-postgres
DB_POSTGRESDB_PASSWORD=mypasswd
DB_POSTGRESDB_USER=postgres
EXECUTIONS_MODE=queue
QUEUE_BULL_REDIS_HOST=n8n-redis
N8N_ENCRYPTION_KEY=
N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
- Create Redis Container
docker run --name n8n-redis --network=n8n -d -p 6379:6379 redis
- Create PostgreSQL Container
docker run --name n8n-postgres --network=n8n -e POSTGRES_PASSWORD=mypasswd -p 5432:5432 -d postgres
- Create n8n Main Instance
docker run --name n8n-main --env-file .n8n/queue.env --network=n8n -p 5678:5678 n8nio/n8n
- Create Worker Instances
docker run --name n8n-worker1 --env-file .n8n/queue.env --network n8n n8nio/n8n worker
For additional worker instances, run:
docker run --name n8n-worker2 --env-file .n8n/queue.env --network n8n n8nio/n8n worker
- Verify Docker Containers
Check if all necessary containers are running with:
docker ps
Testing Queue Mode
- Open n8n Main Instance
Access the n8n interface:
Import a Test Workflow
Copy the workflow JSON from the provided test document, paste it into the n8n workflow editor, activate and save the workflow. -
Monitor the Workflow Execution
Check logs in your terminal windows to ensure tasks are distributed among worker instances.
Second-Level Scaling: Handling Webhooks Separately
To offload webhook handling to a dedicated instance, run:
docker run --name n8n-webhook1 --env-file .n8n/queue.env --network n8n n8nio/n8n webhook
Troubleshooting and Monitoring
- Checking Logs
docker logs -f
- Checking Redis Connectivity
docker exec -it n8n-redis redis-cli
ping
- Checking PostgreSQL Connectivity
docker exec -it n8n-postgres psql -U postgres
SELECT datname FROM pg_database;
Debugging Execution Failures
Check execution history in the n8n UI under Executions. -
Monitoring Resource Usage
docker stats
Conclusion
By following this setup, you successfully configure n8n to run in queue mode with Redis and PostgreSQL, ensuring efficient workload distribution and scalability.
