Queue Mode: Main Process & Worker Processes on Same Machine
Hey, I’m curious if the following is possible for running n8n in queue mode:
  • A single machine, configured via Docker
  • The main n8n process running
  • Several worker processes running as well.
Redis and Postgres would be on separate machines.
In most of the guides for scaling n8n, the setup involves utilizing separate machines for workers and main.
But instead of that, is it possible to run multiple instances of n8n on same machine with one as main and several others as workers?
My thinking is that if I have a 4 vCPU vm, I could have one main process and 3 worker processes. Is this possible?
Thanks.
Technically yes, all you need to make sure is that each worker has a unique/different port. Lemme see if I can put together a docker-compose
If you’re using docker swarm or kubernetes, it’ll prob be easier to spin up more workers.
Example docker-compose.yml:
services:
  n8n-queue-db:
    image: postgres:16.1
    container_name: n8n-queue-db
    restart: always
    environment:
      - POSTGRES_DB=n8n
      - POSTGRES_PASSWORD=n8n
      - POSTGRES_USER=n8n
      # - PGDATA=/var/lib/postgresql/data/pgdata
    volumes:
      - /var/containers/volumes/n8n-queue/postgres-data:/var/lib/postgresql/data
  n8n-redis:
    image: redis:7-alpine
    container_name: n8n-redis
    restart: always
    volumes:
      - /var/containers/volumes/n8n-queue/redis-data:/data
  n8n-main:
    image: docker.n8n.io/n8nio/n8n:latest
    container_name: n8n-main
    restart: always
    depends_on:
      - n8n-queue-db
      - n8n-redis
    volumes:
      - /var/containers/volumes/n8n-queue/app-data:/home/node/.n8n
    ports:
      - 5678:5678
    environment:
      - DB_TYPE=postgresdb
      - DB_POSTGRESDB_DATABASE=n8n
      - DB_POSTGRESDB_HOST=n8n-queue-db
      - DB_POSTGRESDB_PORT=5432
      - DB_POSTGRESDB_USER=n8n
      - DB_POSTGRESDB_SCHEMA=n8n
      - DB_POSTGRESDB_PASSWORD=n8n
      - N8N_RUNNERS_ENABLED=true
      - N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
      # Database connection settings
      - DB_POSTGRESDB_POOL_SIZE=5
      - DB_POSTGRESDB_CONNECTION_TIMEOUT=30000
      # Queue mode configuration
      - EXECUTIONS_MODE=queue
      - QUEUE_BULL_REDIS_HOST=n8n-redis
      - QUEUE_BULL_REDIS_PORT=6379
      - QUEUE_BULL_REDIS_DB=0
      - OFFLOAD_MANUAL_EXECUTIONS_TO_WORKERS=true
  n8n-worker-1:
    container_name: n8n-worker-1
    restart: always
    command: worker
    depends_on:
      - n8n-queue-db
      - n8n-redis
    volumes:
    ports:
      - 5679:5678
    environment:
      - DB_POSTGRESDB_POOL_SIZE=3
  n8n-worker-2:
    container_name: n8n-worker-2
    restart: always
    command: worker
    depends_on:
      - n8n-queue-db
      - n8n-redis
    volumes:
    ports:
      - 5680:5678
    environment:
networks:
  default:
    external: true
Load being shared between workers
Perfect, that’s just what I needed to know, thanks @Wouter_Nigrini
Ok great. Please mark my answer as the solution if this helped
