RAG chatbot speed
Hi everyone,
I’m building a RAG-based chatbot assistant for a website, self-hosted on a VPS using n8n. My current stack involves: AI Agent + OpenAI (gpt-4o-mini) + Pinecone vector database.
I’m struggling with high latency: it often takes 16-18 seconds to get a response after a user sends a message.
I’m looking to optimize the user experience and would love your advice on two points:
  1. Reducing Response Time: What are the best practices for speeding up n8n Agent and Pinecone queries? I’m already using gpt-4o-mini. Would shortening the system prompt, reducing the topK value in Pinecone, or switching from an AI Agent to a specific Chain (like Retrieval QA) make a significant difference?
  2. Custom Preloader/Status Messages: The default n8n chat widget only shows the three typing dots (typing indicator) during the wait. Is there a way to display custom status messages instead (e.g., “Searching database…”, “Formulating response…”) to keep the user engaged?
  3. Streaming: Does anyone have experience enabling “Stream Responses” in this setup? Can it effectively mask the latency by showing characters as they are generated?
    Server Specs: Hostinger, 4 vCPU, 16GB RAM
I’d appreciate any insights or tips on how to bring this delay down to a few seconds. Thanks in advance!
Hi @tamy.santos
Thanks, this makes sense. I’ll start by removing the AI Agent and switching to a single-step RAG flow, then reduce LLM calls and context size. Appreciate the clear breakdown :+1:
I hope everything goes well.
If this solution solved the issue for you, please consider leaving a like or marking the reply as the solution ( it helps others find the answer more easily and also supports community contributors.)
Hi @Svetislav_Kondic To reduce latency of RAG chatbot, reduce Pinecone work (lower topK, use smaller embeddings), simplify prompts, use more direct Retrieval QA chain instead of full AI Agent, enable streaming responses so tokens arrive as generated, and serve your UI via webhook/Respond to Webhook endpoint with custom status messages instead of default widget to boost perceived responsiveness, And make sure to not give a huge system prompt, for styling the webhooks HTML just use some static site generator that would help you out. Please do not consider AI generated responses like that and flag them as soon as possible.
Hi @Anshul_Namdev
Thanks for the advice! This is very helpful — I’ll simplify the flow, reduce Pinecone load, and switch to a more direct Retrieval QA approach. Appreciate the tips on streaming and UI responsiveness as well :+1:
Super! Let me know how that goes.
Hey @Svetislav_Kondic,
I’ve been dealing with the same latency issues on production RAG chatbots and found a solution that consistently brings response time from ~16s down to ~3-5s (excluding LLM generation streaming).
The core problem: The native n8n AI Agent node adds significant overhead — it makes multiple internal LLM calls (tool selection, reasoning loops, memory management) before even touching your actual query. For a straightforward RAG pipeline, this is unnecessary.
The fix: Decompose the RAG pipeline into raw HTTP nodes.
Instead of using the AI Agent + Vector Store Retriever chain, I split the flow into explicit steps:
  1. Embed the query → direct HTTP POST to your embedding API (Mistral, OpenAI, etc.)
  2. Vector search → direct HTTP POST to your vector DB’s RPC/query endpoint (Supabase pgvector, Pinecone, etc.)
  3. Build the LLM prompt → a simple Code/Set node that injects retrieved chunks into a system prompt
  4. Call the LLM → direct HTTP POST to the completion API
  5. Parse & return → extract the response
Each step is a single, predictable HTTP call with no hidden overhead.
Here’s a minimal working example for steps 1-2 (embedding + vector retrieval via Supabase RPC):
Then add a Code node to build the LLM request (inject chunks into prompt), followed by another HTTP Request to call the LLM completion endpoint directly — with stream: true if your frontend supports SSE.
Why it’s faster:
AI Agent node Raw HTTP pipeline
LLM calls 2-4 (tool selection + reasoning + answer) 1 (answer only)
Embedding Via sub-node chain Direct HTTP (~200ms)
Vector search Via sub-node chain Direct HTTP (~100-300ms)
Overhead Memory management, tool parsing None
Additional tips:
  • Use executeOnce: true on HTTP nodes to avoid duplicate calls
  • Set explicit timeout values (15s) with retryOnFail
  • Keep match_count low (3-5 chunks) — more context ≠ better answers
  • In my exemple Supabase + pgvector, create an index for faster similarity search
  • Enable streaming on the final LLM call for perceived instant responses
This approach gives you full control over every step, makes debugging trivial, and eliminates all the hidden overhead of the AI Agent abstraction.
