Rag pinecone vector store Recursive Character Text Splitter not returning output
I ma using 14 day trail n8n and try to build rag using google drive trigger and p
Pinecone Vector Store , it is connected with OenAI Embedding Node with Model text Embedding 3 small  and default Data loader then in turn with REcursive Character Text Splitter all , when executing workflow workflow executed smoothly but Recursive text splitter not returning out put, and embedding also. jsone is uploaded , pleas guide
## What is the error message (if any)? No error code run smoothly
## Please share your workflow  shared beloe
(Select the nodes on your canvas and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow.){
“name”: “RAGtry”,
“nodes”: [
  "parameters": {
    "pollTimes": {
      "item": \[
          "mode": "everyMinute"
    "triggerOn": "specificFolder",
    "folderToWatch": {
      "\__rl": true,
      "value": "1M0BWgtxVbbLNdWea6bh-Mb2cL9TAexl\_",
      "mode": "list",
      "cachedResultName": "gdrivragn8n",
      "cachedResultUrl": "https://drive.google.com/drive/folders/1M0BWgtxVbbLNdWea6bh-Mb2cL9TAexl\_"
    "event": "fileCreated",
    "options": {}
  "type": "n8n-nodes-base.googleDriveTrigger",
  "typeVersion": 1,
  "position": \[
    -624,
    -128
  "id": "27a29031-4dac-4208-955f-5a6763d63d56",
  "name": "file created",
  "credentials": {
    "googleDriveOAuth2Api": {
      "id": "nblAFBF7cgVS8xBY",
      "name": "Google Drive account"
  "parameters": {
    "pollTimes": {
      "item": \[
    "folderToWatch": {
      "\__rl": true,
      "mode": "list",
    "event": "fileUpdated",
    "options": {}
  "typeVersion": 1,
  "position": \[
    -608,
    16
  "id": "9f8d1730-3e5b-417a-85ee-a4a20a985077",
  "name": "file updated",
  "credentials": {
  "parameters": {
    "operation": "download",
    "fileId": {
      "\__rl": true,
      "value": "1ZmJKD9qmd0HFtZWM6yeOs4jD1VUtTYh2",
      "mode": "list",
      "cachedResultName": "INS-CIR-202-2023 Roshan Ghar.pdf",
      "cachedResultUrl": "https://drive.google.com/file/d/1ZmJKD9qmd0HFtZWM6yeOs4jD1VUtTYh2/view?usp=drivesdk"
    "options": {}
  "type": "n8n-nodes-base.googleDrive",
  "typeVersion": 3,
  "position": \[
    -368,
    -64
  "id": "2d353411-4d5d-4adb-9031-5d5d57cfd182",
  "name": "Download file",
  "credentials": {
  "parameters": {
    "mode": "insert",
    "pineconeIndex": {
      "\__rl": true,
      "value": "pineragn8n",
      "mode": "list",
      "cachedResultName": "pineragn8n"
    "embeddingBatchSize": 50,
    "options": {}
  "type": "@n8n/n8n-nodes-langchain.vectorStorePinecone",
  "typeVersion": 1.3,
  "position": \[
    -112,
    -128
  "id": "2df7dcf2-3199-4dfe-aaa7-0382c51fb972",
  "name": "Pinecone Vector Store",
  "credentials": {
    "pineconeApi": {
      "id": "16i7Qpz2A4mFKHyJ",
      "name": "Pinecone account"
  "parameters": {
    "options": {
      "dimensions": 1536,
      "batchSize": 50
  "type": "@n8n/n8n-nodes-langchain.embeddingsOpenAi",
  "typeVersion": 1.2,
  "position": \[
    -288,
    112
  "id": "c72d7486-9eae-4098-ac8a-912a67718770",
  "name": "Embeddings OpenAI",
  "credentials": {
    "openAiApi": {
      "id": "TYquTcltzWfp5Ok3",
      "name": "paidopenapikey"
  "parameters": {
    "dataType": "binary",
    "textSplittingMode": "custom",
    "options": {
      "metadata": {
        "metadataValues": \[
            "name": "filename",
            "value": "={{ $('Download file').item.json.name }}"
  "type": "@n8n/n8n-nodes-langchain.documentDefaultDataLoader",
  "typeVersion": 1.1,
  "position": \[
    64,
    0
  "id": "22159453-fbec-4177-8f4b-4695f0d4e5a3",
  "name": "Default Data Loader",
  "alwaysOutputData": true
  "parameters": {
    "chunkSize": 500,
    "chunkOverlap": 50,
    "options": {}
  "type": "@n8n/n8n-nodes-langchain.textSplitterRecursiveCharacterTextSplitter",
  "typeVersion": 1,
  "position": \[
    -64,
    112
  "id": "4be330dd-db9f-45e2-bbf5-9a2eae900e1c",
  "name": "Recursive Character Text Splitter"
“pinData”: {},
“connections”: {
"file created": {
  "main": \[
        "node": "Download file",
        "type": "main",
        "index": 0
"file updated": {
  "main": \[
        "type": "main",
        "index": 0
"Download file": {
  "main": \[
        "node": "Pinecone Vector Store",
        "type": "main",
        "index": 0
"Embeddings OpenAI": {
  "ai_embedding": \[
        "type": "ai_embedding",
        "index": 0
"Default Data Loader": {
  "ai_document": \[
        "type": "ai_document",
        "index": 0
"Recursive Character Text Splitter": {
  "ai_textSplitter": \[
        "node": "Default Data Loader",
        "type": "ai_textSplitter",
        "index": 0
“active”: false,
“settings”: {
"executionOrder": "v1",
"binaryMode": "separate"
“versionId”: “36c72e83-e44b-4da3-a783-2241c34395a4”,
“meta”: {
"instanceId": "568d41a4614a8599d7d1a2f4e3b0342bbe612b20a7e08ef74b5213c08d404de4"
“id”: “UCej8PnySomyBnAG”,
“tags”: [
  "updatedAt": "2026-04-17T17:07:25.816Z",
  "createdAt": "2026-04-17T17:07:25.816Z",
  "id": "IlsRlIPkBq3Jg5l2",
  "name": "RAG"
## Share the output returned by the last node
<!-- If you need help with data transformations, please also share your expected output. -->
* **n8n version:**
* **Database (default: SQLite):**
* **n8n EXECUTIONS_PROCESS setting (default: own, main):**
* **Running n8n via (Docker, npm, n8n cloud, desktop app):**
* **Operating system:**
Hi @Moqeem_Ahmad1
The recommended approach for the insertion of documents in pinecone is below:
And so you instead of using text splitting CUSTOM use it simple, and there if you want you can also choose “Load Specific Data” instead of all incoming data for more accurate and meaningful retrieval, give this a shot and let me know how this goes.
@Moqeem_Ahmad1 the sub-nodes (text splitter, embeddings, loader) never show output in the execution panel, that’s normal — they get processed internally by the vector store node. check your Pinecone dashboard to see if vectors actually landed. here’s a quick retrieval test workflow to verify:
plug your existing Pinecone and OpenAI creds in, ask it something from your PDF — if it returns results your insert workflow actually worked fine, the UI just doesn’t display sub-node output.
Hi, Anshul_Namdev thanks that is resolved but rag not replying accurate answer , what type of files can be uploaded, i load .pdf but not work although pincone index updated successfully
thanks dear
@Moqeem_Ahmad1 share your data ingestion workflow in Pinecone. Maybe there is something wrong if the retrieval is not accurate or inconsistent
HI, THANKS FORYOU SUPPORT, I WLL SHARE AS SOME BUSY IN SOME OTHER TASK. With Default loader using simple rather custom completed the task . thanks
hi,
Thanks, resolve as per early guidance. thanks please
@Moqeem_Ahmad1 Please consider marking the solution to whichever answer helped you.
Thanks!
Anshul.
