RangeError: Maximum call stack size exceeded in function node | n8n v0.199.0
I have basic function node with return statement for the next node. But it’s
    at SecureContext.hasOwnProperty (<anonymous>)
    at deepCopy (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/src/utils.js:24:13)
    at deepCopy (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/src/utils.js:25:45)
  • n8n version: 0.199.0
  • Database you’re using (default: SQLite): Postgres
  • Running n8n with the execution process [own(default), main]: own
  • Running n8n via [Docker, npm, n8n.cloud, desktop app]: docker - cloud run in GCP
Seems a issue with version post 0.198.1 rolling back solved the RangeError: Maximum call stack size exceeded It seems code around function node is recursing infinitely
Hey @Deshdeep,
Thanks for reporting this one, It looks like the team have spotted it and have a fix in place already. I know we are planning a release later today and I suspect this may be part of it.
Fix got released with [email protected]
