I am having trouble with some of the examples in the book and thus I have questions about them. Do any of the authors answer questions in this forum?
1.) on page 130 I can’t get the IF node to return results to the “TRUE” side.
Here is my code:
2.) on page 142 I can’t get WorkFlow 1 to run WorkFlow 2
Here is the code:
Thank you for your help.
- n8n version:
- Database (default: SQLite):
- Operating system:
I’m not familiar with the book so can’t comment on the first question, but for the second question you need to set the numeric ID of the subworkflow you’re calling in the ‘execute workflow’ node. You can find this either in the URL or the workflow settings:
Yes, thank you. I found the numeric ID of the subworkflow and input it in the database setting where it asks for the numeric ID, but now I get the following error: " ERROR: Your request is invalid or could not be processed by the service
Unknown field name: “created_at”
Do I need a set node before the Execute Workflow node?
Details
Execute Workflow
Execute node
Parameters
Docs
Source
Fixed
Expression
Workflow ID
Fixed
Expression
Any data you pass into this node will be output by the Execute Workflow Trigger. More info
I wish this node would…"
