Rate limit for webhook entry node
Hi n8n community!
Please forgive me if the question has already been answered, the info I could find is a bit old.
I was wondering whether there is a rate limit on the webhook node used as a flow’s entry point. I might have a bit of volume sometimes coming all at once (<3000), should I split it in batches before?
Thanks,
Hi @Romain1, welcome to the community!
The webhook node is a trigger node, meaning it’d be the first node in a workflow. So a Split in Batches node would therefore have no effect on the webhook volume unfortunately (as it could only run after the webhook).
n8n does not have a built in throttling logic for incoming webhooks I am afraid, but you could consider an external tool (such as Convoy for example) if you are noticing your n8n instance struggling with the amount of webhooks it receives.
Hi @MutedJam and thanks for taking the time to answer me,
In this instance, not having a throttling logic is perfectly fine for me, might be different in other cases, thanks for the tip!
Have a nice day!
