It would help if there was a node for:
branching the execution based on a rate limit.
My use case:
is an procedure that must be executed only 5 times per second. Otherwise the requests should be stored to try later.
More people have requested something similar: Rate limit capability for nodes and Handling rate limiting
Done feat(redis): Add a Redis based rate limiter by tinti · Pull Request #3692 · n8n-io/n8n · GitHub
