ReAct Agent Max Iterations
Is it possible to limit the number of iterations in the ReAct Agent node like I can do in the Tools Agent with the Max Iterations parameter?
Hi @Ranni,
Tip for sharing your workflow in the forum
Pasting your n8n workflow
<your workflow>
Make sure that you’ve removed any sensitive information from your workflow and include dummy data or pinned data as much as you can!
That’s not a possible option in ReAct Agent. What are you building with the ReAct Agent if I may ask? In general, we recommend using the Tools Agent for most use-cases, do you think you can use the Tools Agent instead for whatever you’re building?
Hi! Fortunately, this is an option in LangChain, so I’ve made a fork of n8n and added this parameter.
