Read Binary Files, output is empty
Hello,
I want to send a document to OpenAI. For this, I have a “Local File Trigger” node that works and transmits the path to a “Read Files from disk” node. The latter does not return any value in the output.
I tested with the machine’s internal path “e:..” and via the share "\my_srv... "all services work with a machine admin account.
  • **n8n version:**1.55.3
  • **Database (default: SQLite):**SQLite
  • **n8n EXECUTIONS_PROCESS setting (default: own, main):**default
  • **Running n8n via (Docker, npm, n8n cloud, desktop app):**npm
  • **Operating system:**windows server 2019
I have already used this type of node but with a Docker version and a file located in the container.
Thank you for your help.
Is the PDF very large? I know that you can’t test individual nodes with big PDFs and have to instead use Test Workflow. You could also try to test with a smaller file.
Your settings above for the Read/Write File node are correct and should work.
My PDF is not large, I even tested with different documents. It’s frustrating that it works with the Docker version but not with my regular installation.
