Read parameters in description: INodeTypeDescription
	displayName: 'Endpoint',
	type: 'options',
	options: getEndpointOptions('{{ $parameter["endpointCollection"] }}'),
	default: '',
	displayOptions: {
		show: {
			operation: ['employee'],
	description: 'Endpoints related to operation',
I have this property that im trying to pass in a function that returns options of the selected endpointCollection
However i dont know if there is a better way of reading the parameters in the properties array
or if there is a better way of loading option. The option cant use the displayOptions because they are a lot and it reached limit If there is away please help
n8n version: latest
Database (default: SQLite):
Running n8n via npm:
Operating system: win 11
Hi @Onlypfachi
Check out the loadOptionsMethod and loadOptionsDependsOn properties to dynamically load options based on the value of another property.
Here’s our documentation on this: Base files | n8n Docs
And here’s an example from the community: (Integration) Refresh attributes list automatically
	displayName: 'City',
	typeOptions: {
		loadOptionsDependsOn: ['country'],
You could try to limit the number of options that need to be loaded at once by adding more dependencies or filters, or by limiting the number of options returned by your getEndpointOptions function.
Let us know how you get on! :slight_smile:
thank you @ria this fixed my issue
